Author Topic: ( C3D ) Memory usage  (Read 4274 times)
« on: October 17, 2005, 10:06:27 AM »
How does your memory usage look in C3D?
I use this batch script to output my findings.
@echo off
echo.
echo Current time = %time%
echo Memory usage for ( %1 )
tasklist /fi "IMAGENAME eq %1" /fo table
Open an existing .dwg
Current time =  9:08:17.37
Memory usage for ( acad.exe )
Image Name                   PID Session Name     Session#    Mem Usage
acad.exe                     664 Console                 0    210,548 K
select a point.
Current time =  9:09:17.56
acad.exe                     664 Console                 0    218,492 K
drag a few points around.
Current time =  9:11:13.75
acad.exe                     664 Console                 0    219,464 K
Current time =  9:12:12.29
acad.exe                     664 Console                 0    221,028 K
Current time =  9:13:17.75
acad.exe                     664 Console                 0    222,976 K
select a point, drag it but don't left click, just let it hang there.
Current time =  9:15:38.93
acad.exe                     664 Console                 0    224,736 K
Current time =  9:16:21.81
acad.exe                     664 Console                 0    227,660 K
move some more points around.
Current time =  9:17:25.26
acad.exe                     664 Console                 0    230,640 K
de-select all points.
Current time =  9:18:35.75
acad.exe                     664 Console                 0    223,404 K
don't do any thing in the .dwg and let's see how memory does.
Current time =  9:36:40.15
acad.exe                     664 Console                 0    223,236 K
The more I work in a particular .dwg the worse it gets. Open a couple more .dwgs in the same session and watch what happens!!
Dinosaur
Re: ( C3D ) Memory usage
« Reply #1 on: October 17, 2005, 10:48:51 AM »
Are you using Service Pack 2?  Some postings on the discussion group are reporting similar problems after installing this update.
« Reply #2 on: October 17, 2005, 11:17:53 AM »
Indeed I am. But I'm pretty sure it was the same before installing SP2.
Dinosaur
« Reply #3 on: October 17, 2005, 11:28:25 AM »
I am still on SP1 and don't seem to be having this problem.  I currently have a 9MB base drawing loaded along with 6 others in the project.  Total 18.1 mb and the memory usage is steady.
Dinosaur
« Reply #4 on: October 17, 2005, 03:15:28 PM »
If this starts causing crashes or you need to free up some memory, it appears that minimizing the drawing will free up the memory.
« Reply #5 on: October 17, 2005, 03:33:14 PM »
Indeed it does!! Also gives you back some memory.
Interesting . . .
Dinosaur
« Reply #6 on: October 17, 2005, 04:01:23 PM »
I don't know if this is relevent to your issues, but you have your options for layout Regen caching set to cache model tab and all layout tabs this test is worth a try.
Open task manager and select several tabs and watch the used resources grow. Then go to Options/System and try setting your Layout Regen option to anything other than Cache Model Tab and All Layouts. Then repeat the test and see if your resources stabilize.
