I'm placing this in my startup to verify the current open drawing version last saved in.Code: [Select](princ (strcat "\n*** --------- AutoCAD Release " (rtos (GetDwgVersion (getvar "dwgname")) 2 0) " --------- ***"))
Opening an AutoCAD 2007 format file.Regenerating model.
Quote from: M@yhem on June 25, 2009, 04:23:16 PMQuote from: GDF on June 24, 2009, 03:49:21 PMI'm placing this in my startup to verify the current open drawing version last saved in.Code: [Select](princ (strcat "\n*** --------- AutoCAD Release " (rtos (GetDwgVersion (getvar "dwgname")) 2 0) " --------- ***"))Doesn't AutoCAD already do this? Mine does.Tried on AutoCAD Civil 3D 2013:->; error: no function definition: GETDWGVERSION
Yep, sorry I opened other window of Autocad with no function loaded :ugly:
(getvar "acadver")
Usually I just usedCode: [Select](getvar "acadver")and take first 4 symbols of string
(strcat "AutoCAD " (substr (ver) 13 4) " Version" " => " (substr (getvar "acadver") 1 4))
