Author Topic: acadver info  (Read 16030 times)
Matt__W
  • I like my water diluted.
Re: acadver info
« Reply #15 on: June 25, 2009, 04:23:16 PM »
I'm placing this in my startup to verify the current open drawing version last saved in.
(princ (strcat "\n*** --------- AutoCAD Release " (rtos (GetDwgVersion (getvar "dwgname")) 2 0) " --------- ***"))
Doesn't AutoCAD already do this?  Mine does.
Quote from: My AutoCAD told me so
Opening an AutoCAD 2007 format file.
Regenerating model.
Autodesk Expert Elite
GDF
Re: acadver info
« Reply #16 on: June 25, 2009, 04:32:49 PM »
It does. I quess I had my head in the sand. Anyway it was a good learning curve.
enderprime
Re: acadver info
« Reply #17 on: March 03, 2014, 11:37:15 AM »
Updated with latest releases:
15.0  2000
16.0  2004
16.1  2005
16.2  2006
17.0  2007
17.1  2008
17.2  2009
18.0  2010
18.1  2011
18.2  2012
19.0  2013
19.1  2014
19.2  2015
« Last Edit: August 29, 2014, 10:54:47 AM by ender.prime »
alanjt
  • Standby for witty remark...
Re: acadver info
« Reply #18 on: March 04, 2014, 12:24:50 AM »
Tried on AutoCAD Civil 3D 2013:
; error: no function definition: GETDWGVERSION
The function must be loaded: http://www.theswamp.org/index.php?topic=6774.msg83200#msg83200
Dropbox
NICK_VNV
Re: acadver info
« Reply #19 on: March 04, 2014, 12:31:02 AM »
Yep, sorry I opened other window of Autocad with no function loaded  :ugly:
alanjt
Re: acadver info
« Reply #20 on: March 04, 2014, 12:33:11 AM »
Happens to all of us.  :lol:
Dropbox
NICK_VNV
Re: acadver info
« Reply #21 on: March 04, 2014, 12:37:08 AM »
Usually I just used
(getvar "acadver")
and take first 4 symbols of string
« Last Edit: March 04, 2014, 12:43:08 AM by NICK_VNV »
MeasureUp
Re: acadver info
« Reply #22 on: March 04, 2014, 01:16:52 AM »
Usually I just used
(getvar "acadver")
It may be off the topic, but here is another one:
(strcat "AutoCAD " (substr (ver) 13 4) " Version" " => " (substr (getvar "acadver") 1 4))
« Last Edit: March 04, 2014, 01:20:04 AM by MeasureUp »
