Author Topic: Solved: AutoCAD vs AutoCAD LT Menu Difficulties  (Read 5877 times)
M-dub
Re: Menu Load
« Reply #30 on: September 13, 2005, 11:59:14 AM »
So, is it working now?  Do I understand you correctly?
Kate M
Re: Menu Load
« Reply #31 on: September 13, 2005, 02:44:47 PM »
It only works if you copy the MNS into two separate folders, so that each version can create its own MNC/MNR files. It means you have to maintain two files, but at least you can just copy & replace one of them when you make a change. Then the MNC/MNR files will recompile and you'll be all set again.
So now I have a "Menus\AutoCAD" folder and a "Menus\AutoCAD LT" folder, with the same MNS in each, and everything's fine.
M-dub
Re: Menu Load
« Reply #32 on: September 13, 2005, 03:03:59 PM »
Makes sense.  Glad to hear everything's back to normal!
Andrea
Re: Solved: AutoCAD vs AutoCAD LT Menu Difficulties
« Reply #33 on: September 14, 2005, 12:55:36 PM »
sometimes the MNC file is not correctly compressed..
make sure to delete the MNL MNR and MNC file before re-compress the MNC.
AutoCAD read the MNC file and not the MNS but need MNS to create the MNC.
I have fixed many diffrent problems doing this.  it work all times.
Keep smile...
gerstal82
« Reply #34 on: September 14, 2005, 01:14:15 PM »
You'd better not delete the MNL file. This is a lisp-file used for the other menu files.
This is one file that isn't created on its onw, you have to make it yourself.
Andrea
« Reply #35 on: September 14, 2005, 05:21:34 PM »
sorry..gerstal82
I have made a mistake....you'r right. :|
Keep smile...
