Author Topic: mass properties command  (Read 1467 times)
Rotring
« on: September 11, 2005, 08:58:45 PM »
I'm doing a job where we have to calculate the amounts of cut and fill generated in ACAD 2004.  This is what I've done so far...
Created the contours so that it is a 3d model of the proposed and existing conditions.  Traced round the edges with a 3d polyline.  I'm stuck there cause I thought I could turn the surface into a region, then get the areas with the 'mass property command'.
Does anyone have any prior workings with this  :?   Is this right command or way to do this?
Jürg Menzi
  • Oberegg, Switzerland
Re: mass properties command
« Reply #1 on: September 12, 2005, 02:06:39 AM »
Maybe this one helps:
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
