YOU HAVE NO CHOICE BUT TO USE THE 25 FOOT RADIUS, UNLESS THERE IS OTHER POsESSION EVIDENCE ON THE GROUND. (i hate caps lock!!!!!) You must "retrace" the line per plat of record.
You have to apply a 25' radius curve between the found corner irons. Then either use "curve solver" or set up a curve label routine like I have done with my "showall' label that labels all of the curve data for you, Delta, Length, Tan, Radius, Chord Bearing and Chord Distance (computed or 'Survey") in order to comply with your state requirements under the Florida Minimum Technical Standards (Chapter 16 Florida Administrative Code, Chapter 61G17-6, Paragraph 61G17-6.0031(e)
