Author Topic: Removing some list manipulation from a function decreses performance?  (Read 306 times)
V@no
  • AutoCAD 2023
Hello.
I have a function that returns list of fit points of a spline:
  1. (DEFUN _getPoints (ent / coord result)
  2.    (WHILE (SETQ coord (ASSOC 11 ent))
  3.       (SETQ result (CONS (CDR coord) result)
  4.             ent    (CDR (MEMBER coord ent))
  5.       )
  6.    )
  7.    (REVERSE result)
  8. )
I use it also to count fit points, which seemed like waste of resources, since I could just count the point within the function instead:
  1. (DEFUN _getNumPoints (ent / coord num)
  2.    (setq num 0)
  3.    (WHILE (SETQ coord (ASSOC 11 ent))
  4.       (SETQ ent (CDR (MEMBER coord ent))
  5.             num (1+ num)
  6.       )
  7.    )
  8. )
However, my benchmark shows that _getNumPoints is actually slower, almost twice on spline with 200+ points!
How is this possible? Or my benchmark is incorrect?
  1. (defun c:test (/ ent _getPoints _isNumPoints test test1 test2)
  2.     (DEFUN _getPoints (ent / coord result)
  4.             (SETQ result (CONS (CDR coord) result)
  5.                   ent    (CDR (MEMBER coord ent))
  6.             )
  7.         )
  8.         (REVERSE result)
  9.     )
  10.
  11.
  12.     (DEFUN _getNumPoints (ent / coord num)
  13.         (setq num 0)
  14.         (WHILE (SETQ coord (ASSOC 11 ent))
  15.             (SETQ ent (CDR (MEMBER coord ent))
  16.                   num (1+ num)
  17.             )
  18.         )
  19.     )
  20.
  21.     ; only FIT spline, not CV
  22.     (setq ent (entget (SSNAME (ssget ":S" '((0 . "SPLINE") (-4 . "!=") (74 . 0))) 0)))
  23.     ; start bench
  24.     (setq test1 (car (_vl-times)))
  25.     (repeat 100 (_getNumPoints ent) )
  26.     ;
  27.     (setq test2 (car (_vl-times)))
  28.     (repeat 100 (_getPoints ent) )
  29.     ; result
  30.     (setq test (car (_vl-times)))
  31.     (princ "\n_getNumPoints: ")
  32.     (princ (- test test1))
  33.     (princ "\n_getPoints:    ")
  34.     (princ (- test test2))
  35.     (princ)
  36. )
P.S.
While preparing this question, I've noticed that if I preselect spline before running the test it takes 10 times longer than when spline selected when prompted by the test...huh?
Command: TEST <--- pre selected spline
_getNumPoints: 1030
_getPoints:    542
Command:
Command: TEST <-- nothing pre selected
Select objects:
_getNumPoints: 68
_getPoints:    37
« Last Edit: April 20, 2024, 11:34:15 AM by V@no »
VovKa
  • Ukraine
Re: Removing some list manipulation from a function decreses performance?
« Reply #1 on: April 20, 2024, 11:55:20 AM »
(- test test1) includes time spent for both benchmarks
should be (- test2 test1))
V@no
  • AutoCAD 2023
« Reply #2 on: April 20, 2024, 12:02:12 PM »
/facepalm
Thank you!
Any ideas why it shows different result when object selected prior running the test function, vs object selected during running the function?
VovKa
  • Ukraine
« Reply #3 on: April 20, 2024, 12:34:41 PM »
probably caused by some internal and thus mysterious reasons :)
add (getstring) after line #22
ribarm
  • Marko Ribar, architect
« Reply #4 on: April 20, 2024, 02:00:14 PM »
This part :
  1.     (setq test1 (car (_vl-times)))
  2.     (repeat 100 (_getNumPoints ent) )
  3.     (setq test2 (car (_vl-times)))
  4.     (repeat 100 (_getPoints ent) )
  5.     (setq test (car (_vl-times)))
  6.     (princ "\n_getNumPoints: ")
  7.     (princ (- test test1))
  8.     (princ "\n_getPoints:    ")
  9.     (princ (- test test2))
  10.
Should be :
  5.     (setq test3 (car (_vl-times)))
  7.     (princ (- test2 test1))
  9.     (princ (- test3 test2))
  10.
« Last Edit: April 20, 2024, 02:26:18 PM by ribarm »
M.R. on Youtube
