Author Topic: [XDrx-PlugIn(141)] Reset the starting point of the closed polyline and direction  (Read 212 times)
xdcad
1. Reset the starting point of the closed polyline (lower left, upper left, upper right, lower right)
2. Reset the clockwise direction of a closed polyline
(defun c:xdtb_plreset (/ bb corner left-up pts ss val x)
  (if (not #xd_var_global_polyline_mode)
    (setq #xd_var_global_polyline_mode 1)
  (xdrx_initget "0 1 2 3")
  (if (setq val (getint (xdrx-string-formatex
      (xdrx-string-multilanguage "\n多段线起点[左下(0)/左上(1)/右上(2)/右下(3)]<%d>:" "\nPolyline starting point [lower left (0)/upper left (1)/upper right (2)/lower right (3)]<%d>:")
    (setq #xd_var_global_polyline_mode val)
  (if (not #xd_var_global_polyline_clockwise)
    (setq #xd_var_global_polyline_clockwise 1)
  (xdrx_initget "0 1")
      (xdrx-string-multilanguage "\n时针方向[逆时针(0)/顺时针(1)]<%d>:" "\nClockwise direction [counterclockwise (0)/clockwise (1)]<%d>:") #xd_var_global_polyline_clockwise
    (setq #xd_var_global_polyline_clockwise val)
  (if (setq ss (xdrx-ssget (xdrx-string-multilanguage "\n选择要处理的封闭多段线<退出>:" "\nSelect closed polylines to process <Exit>:")
   '((0 . "*polyline") (-4 . "&=")
    (70 . 1)
      (setq bb nil)
      (mapcar
'(lambda (x)
   (setq pts (xdrx-getpropertyvalue x "vertices")
corner (xdrx-points->4corner pts)
left-up (nth #xd_var_global_polyline_mode corner)
   (setq bb (cons x bb))
   (xd::polyline:resetstartpoint x left-up)
     ((and
(= #xd_var_global_polyline_clockwise 1)
(xdrx-curve-direction x)
       (xdrx-curve-reverse x)
     ((and
(= #xd_var_global_polyline_clockwise 0)
(not (xdrx-curve-direction x))
(xdrx-ss->ents ss)
      (xdrx-prompt (xdrx-string-formatex (xdrx-string-multilanguage "\n重设了%d个多段线起点和时针方向." "\nReset starting point and clockwise direction of %d polylines.")
(sslength ss)
https://github.com/xdcad
http://bbs.xdcad.net
