Author Topic: Evolution of IsIntValue()  (Read 661 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: February 10, 2024, 06:19:50 PM »
This was the evolution of the Extension Method.
If anyone has a cleaner result I'd like to know.
Code - C#: [Select]
  1. //double val = 42.00;
  2. double val = 42.42;
  3.
  4. Console.WriteLine($"{Math.Round(val, 4 , MidpointRounding.AwayFromZero):0.000000}") ;
  5. Console.WriteLine((int)Math.Round(val, 4 , MidpointRounding.AwayFromZero)) ;
  6.
  7. Console.WriteLine(Math.Abs( val - (int) Math.Round(val, MidpointRounding.AwayFromZero)));
  8.
  9. Console.WriteLine(1e-16 );
  10.
  11. Console.WriteLine(Math.Abs( val - (int)Math.Round(val, MidpointRounding.AwayFromZero))
  12.                     < 1e-16
  13.                  );
  14.
  15. Console.WriteLine(val.IsValueInt());
  16.
  17. string message = 50.00001.IsValueInt() ? " value is integral" : " value is NOT integral";
  18.
  19. Console.WriteLine(message);
  20.
  21.
  22. static public class ExHelper
  23. {
  24.         static public bool IsValueInt(this double dvalue) =>
  25.                 Math.Abs(dvalue - (int)Math.Round(dvalue, 4,
  26.                                                         MidpointRounding.AwayFromZero))
  27.                                                         < 1e-16;
  28. }
  29.
OUTPUT:
Code - C#: [Select]
  1. 42.420000
  2. 42
  3. 0.4200000000000017
  4. 1E-16
  5. False
  6. False
  7.  value is NOT integral
  8.
« Last Edit: February 10, 2024, 06:25:22 PM by kdub_nz »
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: Evolution of IsIntValue()
« Reply #1 on: February 11, 2024, 09:34:00 PM »
Something like this will probably suit me better.
Code - C#: [Select]
  1.       [CommandMethod("Test0212")]
  2.       public void Test0212()
  3.       {
  4.
  5.          if (TryIsValueIntegral(101, out int a))
  6.             WriteMessage("\na: " + a);
  7.
  8.          if (TryIsValueIntegral(11.42, out int b))
  9.             WriteMessage("\nb: " + b);
  10.
  11.          if (TryIsValueIntegral("22", out int c))
  12.             WriteMessage("\nc: " + c);
  13.
  14.          if (TryIsValueIntegral("22.42", out int d))
  15.             WriteMessage("\nd: " + d);
  16.
  17.          if (TryIsValueIntegral(1111.00, out int e))
  18.             WriteMessage("\ne: " + e);
  19.
  20.          if (TryIsValueIntegral("122.00", out int f))
  21.             WriteMessage("\nf: " + f);
  22.
  23.       }
  24.
  25.       bool TryIsValueIntegral(double dvalue, out int ivalue)
  26.       {
  27.          ivalue = (int)Math.Round(dvalue, 4, MidpointRounding.AwayFromZero);
  28.          return Math.Abs(dvalue - ivalue) < 1e-16;
  29.       }
  30.
  31.       bool TryIsValueIntegral(string svalue, out int ivalue)
  32.       {
  33.          if (double.TryParse(svalue, out double cvalue))
  34.          {
  35.             ivalue = (int)Math.Round(cvalue, 4, MidpointRounding.AwayFromZero);
  36.
  37.             return Math.Abs(cvalue - ivalue) < 1e-16;
  38.          }
  39.          else
  40.          {
  41.             ivalue = 0;
  42.             return false;
  43.          }
  44.       }
  45.
Code - C#: [Select]
  1. Command: TEST0212
  2. a: 101
  3. c: 22
  4. e: 1111
  5. f: 122
  6.
  7.
Now I just need to parse the resultBuffers ( tomorrow or next )
« Last Edit: February 12, 2024, 03:48:20 AM by kdub_nz »
