Author Topic: DotSpatial-ACadSharp  (Read 1129 times)
sigster
« on: February 06, 2024, 05:32:22 AM »
Hi
Can someone help with this Please
I am try to read Polyline from Shapefile and write to DWG using DotSpatial and ACadSharp
I can read and write the DWG but I get to many Polyline  109 Polyline Instead of 1 Polyline
    Dim vertices As List(Of LwPolyline.Vertex)
     doc.Header.Version = ACadVersion.AC1018
     doc.VPorts(VPort.DefaultName).ShowGrid = False
     For Each vp As VPort In doc.VPorts
         vp.ShowGrid = False
     Next
     Dim shapeActual = FeatureSet.Open(Path)
     Dim FeatureQty As Int16 = shapeActual.Features.Count
     ' Dim plineLst As List(Of Polyline) = New List(Of Polyline)()
     For Each feature As IFeature In shapeActual.Features
         For i As Integer = 0 To feature.Geometry.NumGeometries - 1
             For Each coord As Coordinate In feature.Geometry.GetGeometryN(i).Coordinates
                 Dim typ As DotSpatial.Data.FeatureType = feature.FeatureType
                 If typ = FeatureType.Line OrElse typ = FeatureType.Polygon Then
                     Dim LwPline = New LwPolyline()
                     For Each crd As Coordinate In feature.Geometry.Coordinates
                         vertices = New List(Of LwPolyline.Vertex)() From {
                                    New LwPolyline.Vertex(New XY(crd.X, crd.Y))
                         For i44 As Integer = 0 To vertices.Count - 1
                             LwPline.Vertices.Add(vertices(i44))
                             LwPline.Layer = doc.Layers(Layer)
                         Next
                     Next
                     doc.Entities.Add(LwPline)
                 ElseIf typ = FeatureType.Point Then
                 ElseIf typ = FeatureType.MultiPoint Then
                 ElseIf typ = FeatureType.Unspecified Then
                 End If
             Next
         Next
     Next
Regards
Sigster
ken2023
  • Mosquito
Re: DotSpatial-ACadSharp
« Reply #1 on: March 20, 2024, 07:35:18 AM »
You can debug DotSpace and ACadSharp separately to confirm which step changed 1 to 109.
