(defun c:xdtb_dimvchk (/ box i key ss x)
(defun _keyword (key)
(cond ((= key "D")
(xdrx-entity-delete
(ssget "x" '((0 . "solid") (62 . 2) (-3 ("XDRX"))))
(if (and (xdrx-initget "D")
(xdrx_initssget "" "D" "" "_keyword" "")
(setq ss (xdrx-ssget (xdrx-string-multilanguage "\n选取标注对象[删除检查框(D)]<退出>:"
"\nSelect Dimension object [Delete Check Flag Box (D)]<Exit>:"
'((0 . "dimension*"))
(progn (xdrx-begin)
(setq i 0)
(mapcar '(lambda (x)
(if (and (/= "" (xdrx-getpropertyvalue x "textstring"))
(setq box (xdrx-getpropertyvalue x "textbox"))
(progn (setq i (1+ i))
(xdrx-solid-make (car box)
(last box)
(nth 2 box)
(nth 1 box)
(xdrx-setpropertyvalue (entlast)
"color"
2
"Transparency"
10
(xdrx-xdata-set (entlast) "name" "jck")
(xdrx-draworder->back (entlast))
(xdrx-pickset->ents ss)
(xdrx-prompt
(xdrx-string-formatex
(xdrx-string-multilanguage "\n共发现了%d个标注对象原值被改变."
"\nA total of %d Dimension objects were found to have their original values changed."
i
(if (> i 0)
(xdrx-string-multilanguage "已经标记,请核查."
"Already marked, please check."
(xdrx-end)
