Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
How to update AutoCAD GUI from other threads?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to update AutoCAD GUI from other threads? (Read 645 times)
Andrey Bushman
Swamp Rat
on:
January 21, 2024, 01:22:39 PM »
Windows 10 x64.
AutoCAD 2024.
.Net Framework 4.8.1
Visual Studio 2022
Custom plugin does some long work in the parallel thread. How to initialize updating the StatusBar custom Pane icon when that thread will be finished? In WPF or WinForms I am to update the GUI from other thead via Dispatcher. But how to get something like Dispatcher for AutoCAD?
Code - C#:
[Select]
using
System.Threading.Tasks
using
AcWin
Autodesk
AutoCAD
Windows
using
acad
Autodesk
AutoCAD
ApplicationServices
Application
using
System.IO
using
System.Drawing
using
System.Threading
namespace
Bushman
AutoCAD
Examples
Gui
public
static
class
StatusBarExamples
static
readonly
Icon updateIcon
new
Icon
Path
Combine
Path
GetDirectoryName
typeof
StatusBarExamples
Assembly
Location
@"Icons\update_32.ico"
static
readonly
Icon downloadIcon
new
Icon
Path
Combine
Path
GetDirectoryName
typeof
StatusBarExamples
Assembly
Location
@"Icons\download_32.ico"
static
bool
isUpdateIcon
true
public
static
void
AddCustomPane
var
statusBar
acad
StatusBar
var
doc
acad
DocumentManager
CurrentDocument
if
doc
null
return
var
ed
doc
Editor
Icon getIcon
return
isUpdateIcon
updateIcon
downloadIcon
string
getTooltip
return
isUpdateIcon
"Updating is avaliable"
"Updating is downloaded"
var
customPane
new
AcWin
Pane
ToolTipText
getTooltip
Style
AcWin
PaneStyles
Normal
AcWin
PaneStyles
Command
Icon
getIcon
// It works fine
/* customPane.MouseDown += (o, e) => {
var pane = o as AcWin.Pane;
pane.Icon = getIcon();
pane.ToolTipText = getTooltip();
isUpdateIcon = !isUpdateIcon;
statusBar.Update();
// It doesn't change the icon and tooltip:
customPane
MouseDown
o, e
Task
Run
Thread
Sleep
3000
// some long work...
// In WPF or WinForms I am to update GUI from other thead via Dispatcher.
// But how to get something like Dispatcher for AutoCAD?
var
pane
o
as
AcWin
Pane
pane
Icon
getIcon
pane
ToolTipText
getTooltip
isUpdateIcon
isUpdateIcon
statusBar
Update
statusBar
Panes
Add
customPane
Thank you.
Logged
Andrey Bushman
Swamp Rat
Re: How to update AutoCAD GUI from other threads?
Reply #1 on:
January 22, 2024, 12:02:15 PM »
The problem is solved. Sorry, I can't remove this topic.
Last Edit: January 22, 2024, 12:12:43 PM by Andrey Bushman
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Reply #2 on:
January 22, 2024, 02:02:04 PM »
What was the solution Andrey ?
Logged
Called Kerry in my other life
I live at UTC + 13.00
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
