Author Topic: CAD File is 63MB with images  (Read 1442 times)
HasanCAD
« on: January 17, 2024, 04:44:54 AM »
I copies images in cad file, CAD file without images is 0.5 MB and images total 2.0MB
But the CAD file now is 63.0MB
Why is this?
How to reduce the file size?
rkmcswain
Re: CAD File is 63MB with images
« Reply #1 on: January 17, 2024, 08:55:23 AM »
You pasted these in? And now they are OLE objects?
If you make a copy of this DWG, and start deleting things, when does the file size drop?
IOW - Trial and error
HasanCAD
« Reply #2 on: January 18, 2024, 04:03:28 AM »
Yes, I Pasted these in, They Are OLE object.
I deleted all objects, but the file is 30MB.
The file is empty.
https://1drv.ms/u/s!ApyYNfqm2se6nUUaWSCprbmm3zbG?e=7sPLTi
57gmc
« Reply #3 on: January 18, 2024, 01:43:32 PM »
It contains a non-purgable block that is used by render lights. It is also why you can't delete some layers.
HasanCAD
« Reply #4 on: January 19, 2024, 10:32:17 PM »
Thanks 57gmc
Shay Gaghe
« Reply #5 on: April 09, 2024, 09:43:34 PM »
hi
im using this tool
https://apps.autodesk.com/ACD/en/Detail/Index?id=3955584821612203149&appLang=en&os=Win32_64
its reduces the master file and all its xreferences
