Author Topic: Create a hatch with multple area region  (Read 624 times)
pingoo666
  • Mosquito
« on: January 05, 2024, 08:57:18 AM »
Hello and happy new year !
I try to create a hatch with a region for outer loop.
I use this method :
(vla-appendouterloop hobj
        (vlax-make-variant
            (vlax-safearray-fill
                (vlax-make-safearray vlax-vbobject '(0 . 0))
                (list obj1)
The code works like a charm except if the region has multiple areas
any ideas ?
ribarm
  • Marko Ribar, architect
Re: Create a hatch with multple area region
« Reply #1 on: January 05, 2024, 10:42:02 AM »
1. explode REGION with multiple areas
2. recreate multiple REGIONS with REGION command by using (ssget "_P") right after explode applied
3. use (ssget "_A" '((0 . "REGION") (8 . "layernamewhereresideregions"))) to acquire sel. set of reference regions
4. iterate througn sel. set and apply your sub for hatching on every item stored in sel. set
M.R. on Youtube
