Author Topic: [XDrX-PlugIn(51)] Merge Hatches  (Read 1382 times)
xdcad
« on: December 18, 2023, 01:17:38 PM »
(defun c:XDTB_HaMerge (/ ss ss1 nums)
  (if (and (setq ss
  (xdrx-ssget
    (if (xd::doc:acadischs)
      "\n请选取要合并的HATCH实体[全选(All)]<退出>:"
      "\nPlease select the HATCH entities to be merged<Exit>:"
    '((0 . "HATCH"))
   (> (setq nums (sslength ss)) 1))
      (if (xdrx_hatch_merge ss)
(xdrx-prompt
  (xdrx-string-formatex
      "\n共选取了 %d 个HATCH实体,合并成了"
      "\nA total of %d HATCH entities were selected and merged into 1 ."
    nums
    (xdrx-prompt
"\n没有选到填充或者数量为1,未完成合并。"
"\nNo Hatch is selected or the sums is 1, and the merge is not completed."
« Last Edit: January 10, 2024, 06:01:42 PM by xdcad »
https://github.com/xdcad
http://bbs.xdcad.net
reyas1123
Re: [XDrX-PlugIn(51)] Merge Hatches
« Reply #1 on: January 06, 2024, 06:49:04 AM »
Got some error
Command: XDTB_HAMERGE
; error: no function definition: XD::DOC:ACADISCHS
Hugo
« Reply #2 on: January 06, 2024, 08:39:20 AM »
Everything is ok for me and works perfectly
xdcad
« Reply #3 on: January 06, 2024, 08:48:41 AM »
Got some error
Go here: https://github.com/xdcad/XDrx-API
Download and install the API, then...
