Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(39)] Specify tolerance polyline curvature
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(39)] Specify tolerance polyline curvature (Read 796 times)
xdcad
Swamp Rat
WWW
on:
December 10, 2023, 11:50:05 AM »
Code - Auto/Visual Lisp:
[Select]
defun
c:tt
defun
_remove
arc
setq
cinx
vl-position
seg segs
setq
prevseg
nth
1-
cinx
segs
nextseg
nth
1+
cinx
segs
if
and
xdrx
object
iskindof prevseg
"kLineSeg3d"
xdrx
object
iskindof nextseg
"kLineSeg3d"
progn
if
setq
ints
xdrx
entity
intersectwith prevseg nextseg
3
progn
setq
ints
car
ints
xdrx
setpropertyvalue poly
"removevertexat"
inx
xdrx
"pointat"
list
inx ints
t
defun
_process
poly
if
not
xdrx
getpropertyvalue poly
"isOnlyLines"
progn
setq
segs
xdrx
"allsegs"
setq
inx
0
foreach
seg segs
if
xdrx
object
iskindof seg
"kCircArc3d"
progn
setq
radius
xdrx
getpropertyvalue seg
"radius"
if
radius #xd
var
poly
arc
radius
progn
_remove
arc
setq
inx
1-
inx
setq
inx
1+
inx
;main program
xdrx
begin
if
not
#xd
var
poly
arc
radius
setq
#xd
var
poly
arc
radius
1.0
if
setq
temp
getreal
xdrx
string
format
\n
Please output the recurvature radius tolerance <%0.1f>:"
#xd
var
poly
arc
radius
setq
#xd
var
poly
arc
radius temp
if
setq
ss
xdrx
ssget
\n
Select the polyline to be recurved<Exit>:"
0
"*polyline"
mapcar
lambda
poly
_process poly
xdrx
ss
ents ss
xdrx
end
princ
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
