Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(36)] Hole (circle) statistical details table
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(36)] Hole (circle) statistical details table (Read 707 times)
xdcad
Swamp Rat
WWW
on:
December 04, 2023, 08:25:34 AM »
Code - Auto/Visual Lisp:
[Select]
Plug-in name: Circle statistics table
Author: XDSoft
Running environment: XDRX API / XD Toolbox
Release time: 2016-10-15
Plug-in introduction: Count circles and group numbers to generate tables
Command name: XDTB_TJCir
defun
c:XDTB_TJCir
#height class1 class2 ents lst
pt ss str1 str2 tlst2 val x
y
defun
_maketable
lst
if
setq
pt
getpoint
\n
Table Insert Postion<Exit>:"
progn
setq
lst
xd::table:celltile
list
"Number"
"Coding"
"Aperture"
"Coord X"
"Coord Y"
1
lst
lst
cons
list
"Hole Number Table"
nil
nil
nil
nil
lst
XD::Table:MakeFromList
lst
trans
pt
1
0
#xd_var_text_height
#xd_var_text_height
2.0
xdrx
setpropertyvalue
entlast
"color"
7
princ
defun
_format
val
xdrx_string_regexpr
.[0-9]+)0{1,}$"
val
defun
_write
lst
setq
tlst2
nil
setq
class1
"A"
mapcar
lambda
x
setq
class2
"0"
mapcar
lambda
y
setq
str1
strcat
class1
setq
class2
itoa
1+
atoi
class2
xdrx_text_make
cadr
y
str1
#xd_var_text_height
xd::ucs:
angle
XD::Text:AdjustAlignMent
entlast
1
2
xdrx_entity_move
entlast
trans
xd::geom:get9pt
entlast
5
1
0
cadr
y
setq
str2
strcat
"Φ"
rtos
2
last
y
2
#xd_var_text_bits
y
trans
cadr
y
0
1
setq
tlst2
cons
list
str1
str2
_format
rtos
car
y
2
4
_format
rtos
cadr
y
2
4
tlst2
x
setq
class1
chr
1+
ascii
class1
lst
_maketable
reverse
tlst2
if
not
#xd_var_text_height
setq
#xd_var_text_height
3.5
if
setq
val
getreal
xdrx_prompt
\n
Text Height<"
#xd_var_text_height
t
setq
#xd_var_text_height val
if
not
#xd_var_text_bits
setq
#xd_var_text_bits
1
if
setq
val
getint
xdrx_prompt
\n
Enter the number of decimal places<"
#xd_var_text_bits
t
setq
#xd_var_text_bits val
if
setq
ss
xd::
ssget
\n
Select the circle of statistics <Exit>"
0
"circle"
progn
xdrx_begin
xdrx_sysvar_push '
"dimzin"
0
setq
ents
mapcar
lambda
x
list
xdrx_getpropertyvalue x
"area"
cons
x
"center"
"radius"
xdrx_pickset
ents ss
setq
ents
xd::
list
:groupbyindex ents
0.0
setq
ents
vl-sort
ents '
lambda
x y
car
x
car
y
setq
ents
mapcar
lambda
x
setq
y
cdr
x
vl-sort
y
lambda
x1 y1
car
car
x1
"center"
car
car
y1
"center"
ents
xd::text:init
1
_write ents
xdrx_end
princ
Last Edit: December 04, 2023, 08:28:35 AM by xdcad
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
