Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(29)] Modify Mleader Text height (can be modified by Scale)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(29)] Modify Mleader Text height (can be modified by Scale) (Read 952 times)
xdcad
Swamp Rat
WWW
on:
December 03, 2023, 07:58:54 AM »
Code - Auto/Visual Lisp:
[Select]
defun
c:tt
if
and
xdrx
initget
"0 1"
setq
mode
getkword
\n
Mode[Scale(0)/Height(1)]<Exit>:"
xdrx
initget
cond
mode
"0"
setq
scl
getreal
\n
Enter text scaling <exit>:"
mode
"1"
setq
height
getreal
\n
sEnter leader text height <exit>:"
t
nil
setq
ss
xdrx
ssget
\n
Select The MLeader <Exit>:"
0
"m*leader"
progn
xdrx
begin
setq
nums
sslength
ss
mapcar
lambda
x
setq
h
xdrx
getpropertyvalue x
"textheight"
if
mode
"0"
setq
h
scl h
setq
h height
xdrx
setpropertyvalue x
"textheight"
h
xdrx
ss
ents ss
xdrx
prompt
\n
Successfully Processing "
nums
"Mleader Leaderline."
xdrx
end
princ
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
