I found it on the lisp CA array forum with the number of times and input distances of a DVH with lisp C1 copy text increasing with his prefix 3DUY
But the disadvantage of C1 is that it picks points, so copying a lot takes a long time. CA copies quickly but the text does not increase, so I hope you combine the CA lisp with C1 to form a lisp that copies an increasing text array.
I was looking for a lisp written by a DVH to increase the text array, but it was a long time ago, 2016, so text with a prefix, for example 2D-3C-01, when copied, will jump to 000002.
I hope you guys can go ahead and help me.
Thank you sincerely.
The Tcout command is also good, but you can't add 0, for example 2D-3C-01, then Tcout will only have 2D-3C-1 and have to find 2D-3C- to 2D-3C-0
