Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(23)] Rebuild Hatch Boundary (4 methods)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(23)] Rebuild Hatch Boundary (4 methods) (Read 999 times)
xdcad
Swamp Rat
WWW
on:
December 01, 2023, 09:18:24 PM »
the first method:
Convert Hatch to MPolygon, then convert MPolygon back to Hatch
Code - Auto/Visual Lisp:
[Select]
defun
c:tt
if
setq
ss
xdrx
ssget
\n
Select Hatch to Rebuild the Boundary <Exit>:"
0
"hatch"
progn
xdrx
begin
setq
nums
sslength
ss
mapcar
lambda
x
setq
mp
xdrx
hatch
mpolygon x
ha
xdrx
mpolygon
hatch mp
xdrx
entity
matchprop x ha
setq
ha
xdrx
ss
getsub ha '
0
"hatch"
ha1
ssname
ha
0
xdrx
object
swapid x ha1
xdrx
entity
delete ha1
xdrx
entity
setcolor
xdrx
getpropertyvalue x
"assocobjids"
7
xdrx
ss
ents ss
xdrx
prompt
\n
Successfully Created "
nums
" Hatch Boundary."
xdrx
end
princ
Last Edit: December 01, 2023, 10:47:29 PM by xdcad
Logged
The code I wrote uses XDRX-API,which can be downloaded from github.com and is updated at any time.
https://github.com/xdcad
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
xdcad
Swamp Rat
WWW
Re: [XDrX-PlugIn(23)] Rebuild Hatch Boundary
Reply #1 on:
December 01, 2023, 09:55:47 PM »
the second method:
1.make hatch
2. append loop to Hatch
3. The Loop is Assoc to Hatch
[Select]
defun
c:tt
if
setq
ss
xdrx
ssget
\n
0
"hatch"
progn
xdrx
begin
setq
nums
sslength
ss
mapcar
lambda
x
setq
loops
xdrx
getpropertyvalue x
"getloops"
;;Get Hatch ALL Loops
setq
ha
xdrx
hatch
make
;;Make a Memory Hatch
ha
xdrx
entity
make ha
;;Create to Database
mapcar
lambda
loop
setq
e
xdrx
entity
make loop
;;Create Loop Curve To Database
xdrx
setpropertyvalue ha
"appendloop"
list
0
e
;;Append Loop To Hatch
xdrx
entity
setcolor e
7
loops
xdrx
entity
matchprop x ha
xdrx
object
swapid x ha
;Exchange Objectid,ensure EntityName Not Change
xdrx
entity
delete ha
xdrx
setpropertyvalue ha
"removeloopat"
0
xdrx
ss
ents ss
xdrx
prompt
\n
nums
" Hatch Boundary."
xdrx
end
princ
Last Edit: December 01, 2023, 10:17:38 PM by xdcad
Logged
xdcad
Swamp Rat
WWW
Reply #2 on:
December 01, 2023, 10:10:52 PM »
Third method:
1. Extract HATCH LOOP information,
2. Directly generate LOOP curves
3. In this way, the boundary and HATCH are not Assoc
[Select]
defun
c:tt
if
setq
ss
xdrx
ssget
\n
0
"hatch"
progn
xdrx
begin
setq
nums
sslength
ss
mapcar
lambda
x
setq
loops
xdrx
getpropertyvalue x
"getloops"
;;Get Hatch ALL Loops(AcGe)
setq
e
xdrx
entity
make loops
;Create Loops urve To Database
xdrx
entity
setcolor e
7
xdrx
ss
ents ss
xdrx
prompt
\n
nums
" Hatch Boundary."
xdrx
end
princ
Logged
xdcad
Swamp Rat
WWW
Reply #3 on:
December 01, 2023, 10:45:00 PM »
Method 4
1. Get all LOOPS of the filled entity
2. Use the function (xdrx-hatch-make loops) to directly generate it once
3.loop is assoc
[Select]
defun
c:tt
if
setq
ss
xdrx
ssget
\n
0
"hatch"
progn
xdrx
begin
setq
nums
sslength
ss
mapcar
lambda
x
if
and
setq
loops
xdrx
getpropertyvalue x
"getloops"
setq
e
xdrx
entity
make loops
setq
ha
xdrx
hatch
make e
progn
setq
ha
xdrx
ss
getsub ha '
0
"hatch"
xdrx
entity
matchprop x ha
xdrx
object
swapid x
ssname
ha
0
xdrx
entity
delete ha
xdrx
ss
ents ss
xdrx
prompt
\n
nums
" Hatch Boundary."
xdrx
end
princ
Logged
xdcad
Swamp Rat
WWW
Reply #4 on:
December 01, 2023, 10:46:53 PM »
Method 5
1.root loop creation and filling
2. Get all internal LOOPs
3. Use xdrx-get-intersect to find the intersect of HATCH and internal boundaries.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
XDRX-API
Topic:
