Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(19)] Select 2 points on POLYLINE and drag out a new segment
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(19)] Select 2 points on POLYLINE and drag out a new segment (Read 1037 times)
xdcad
Swamp Rat
WWW
on:
November 28, 2023, 05:29:00 PM »
Mainly introduce point monitoring dynamic drag and AcGe geometry library
Several new functions are introduced:
Code - Auto/Visual Lisp:
[Select]
1
. xdrx
sysvar
push
System variables are pushed onto the stack to save the scene
and
set
new values.
xdrx
sysvar
push '
"osmode"
512
"cmdecho"
0
2
. xdrx
sysvar
pop
The saved system variables are popped out of the stack, one level up,
and
the
last
scene is restored.
xdrx
sysvar
pop
Restore the
last
call to xdrx
sysvar
push, one level
xdrx
sysvar
pop t
Revert to the original call xdrx
sysvar
push
When the above two functions are paired, they can be nested
xdrx
sysvar
push.....
xdrx
sysvar
push....
xdrx
sysvar
pop
xdrx
sysvar
pop
[Select]
defun
c:tt
int1 int2 p1 p2 pts seg inx inx1 inx2 p1
xline p2
xline p1
vecx p2
vecy p1
vecy
Drag the newly added segment and construct an XLINE parallel to P1P2 according to the mouse point dynpt
Find the intersection point with P1 vertical XLINE and P2 vertical XLINE, which is the new position of the two vertices.
defun
_callback
dynpt
xline crvcrvint1 crvcrvint2 int1 int2
drag callback function.
The intersection method of AcGe geometry library is completely used below.
if
not
xdrx
points
iscolinear dynpt p1 p2
;;Mouse Drag Point( DYNPT ) and P1, P2 is not collinear
progn
setq
xline
xdge::constructor
"kLine3d"
dynpt
mapcar
dynpt p1
vecx
crvcrvint1
xdge::constructor
"kCurveCurveInt3d"
xline p1
xline '
0
0
1.0
int1
car
xdge::getpropertyvalue crvcrvint1
"intpoints"
crvcrvint2
xdge::constructor
"kCurveCurveInt3d"
xline p2
xline '
0
0
1.0
int2
car
xdge::getpropertyvalue crvcrvint2
"intpoints"
if have two inter pnt,set the new Vertex
if
and
int1 int2
xdrx
setproperty e
"pointat"
list
inx1 int1
"pointat"
list
inx2 int2
xdge::free crvcrvint1 crvcrvint2 xline
;;Release GE Object Memory
Determine whether the two points P1 and P2 are within the same segment of the polyline
defun
_isSameSeg
e p1 p2
and
setq
seg1
xdrx
getpropertyvalue e
"onsegat"
p1
setq
seg2
xdrx
getpropertyvalue e
"onsegat"
p2
car
seg1
car
seg2
car
seg1
Pick point function, sort two points according to the polyline direction,
Make sure P1 is before P2
defun
_pick
pnt
setq
p1
getpoint
\n
Point to get starting point <exit>:"
setq
p2
getpoint
\n
Click to get the end point <exit>:"
setq
pts
xdrx
points
sortoncurve e
list
p1 p2
mapcar
set
p1 p2
mapcar
cadr
pts
Add two vertices P1 and P2
defun
_add
vertex
xdrx
setpropertyvalue e
"addvertexat"
list
1+
inx
p1
setq
seg
xdrx
getpropertyvalue e
"onsegat"
p2
xdrx
setpropertyvalue e
"addvertexat"
list
1+
car
seg
p2
Construct XLINE through point PT and direction vector vecy
defun
_construct
xline
pnt
pt vecy
xdge::constructor
"kLine3d"
pt
mapcar
pt vecy
Add two new vertices before and after the two picked points
P1 and P2 as the two vertices of the dragged segment.
defun
_construct
drag
2pt
setq
inx1
xdrx
getpropertyvalue e
"nearindex"
p1
_short
len
distance
p1 p2
10.0
setq
temp
p1
mapcar
p1
xdrx
vector
product p1
vecx _short
len
setq
temp
p2
mapcar
p2
xdrx
vector
product
xdrx
vector
negate p1
vecx
_short
len
xdrx
setpropertyvalue e
"addvertexat"
list
1+
inx1
temp
p1
setq
inx1
1+
inx1
setq
inx2
xdrx
getpropertyvalue e
"nearindex"
p2
xdrx
setpropertyvalue e
"addvertexat"
list
inx2 temp
p2
defun
_drag
new
seg
xdrx
pointmonitor
"_callback"
getpoint
\n
Select the appropriate location:"
xdrx
pointmonitor
;; Main Program
xdrx
begin
;;Save the specified system variable and then set the new value
xdrx
sysvar
push '
"osmode"
544
"autosnap"
39
if
and
setq
e
car
xdrx
entsel
\n
Select Polyline <Exit>:"
0
"*polyline"
_pick
pnt
setq
inx
_isSameSeg e p1 p2
_add
vertex
setq
p1
vecx
xdrx
getpropertyvalue e
"firstderiv"
p1
p1
vecy
xdrx
vector
perpvector p1
vecx
setq
p1
xline
_construct
xline
pnt p1 p1
vecy
setq
p2
xline
_construct
xline
pnt p2 p1
vecy
progn
_construct
drag
2pt
_drag
new
seg
;;restore system variable
xdrx
sysvar
pop
xdrx
end
princ
Last Edit: November 28, 2023, 07:58:36 PM by xdcad
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Atook
Swamp Rat
AKA Tim
WWW
Re: [XDrX-PlugIn(19)] Select 2 points on POLYLINE and drag out a new segment
Reply #1 on:
November 28, 2023, 10:28:30 PM »
Very nice, that looks like it could be quite useful for some.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
