Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-Function(3)] xdrx-curve-offset ( xdrx_curve_getoffsetcurves )
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-Function(3)] xdrx-curve-offset ( xdrx_curve_getoffsetcurves ) (Read 993 times)
xdcad
Swamp Rat
WWW
on:
November 28, 2023, 09:35:21 AM »
Code - Auto/Visual Lisp:
[Select]
xdrx
curve
offset
db
ent...ge
ent..ss..
int...real...string
t
exp
xdrx
curve
offset
list
e1 e2 ss
100.0
;Offset the processing curve in the increasing direction
xdrx
curve
offset
list
e1 e2 ss
100.0
;Offset the processing curve in the direction of reduction
xdrx
curve
offset
list
e1 e2 ss
50.0
100.0
200.0
; OFFSET three times in a row
xdrx
curve
offset
list
e1 e2 ss
"50.0,100.0,300.0"
xdrx
curve
offset
list
e1 e2 ss
"50.0,100.0,300.0"
t
; Give the T parameter and return the point list
[Select]
defun
c:tt
if
and
setq
e
xdrx
ssget
\n
Select the curve to be OFFSET<Exit>:"
0
"*line"
and
setq
offsetdist
getstring
\n
Enter OFFSET distance (use, to separate multiple)<Exit>:"
xdrx
string
regexps
"^[-0-9.,]+$"
offsetdist
progn
xdrx
begin
setq
ss
xdrx
curve
offset e offsetdist
xdrx
entity
setcolor ss
1
xdrx
end
princ
Last Edit: December 04, 2023, 01:28:42 PM by xdcad
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
