Author Topic: From Message  (Read 1218 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
From Message
« on: November 27, 2023, 07:54:24 PM »
Hi xdcad
I recently sent you a message , looks like you missed it ?
In
https://www.theswamp.org/index.php?board=78.0   If you make a Topic similar to this:
https://www.theswamp.org/index.php?topic=31866.0
Where you can provide links to your topics or methods, ( or anything you want ),
I can make the Topic stick to the Top of the topic list.
or if you want 2 sticky topics just make the topics , and let me know.
Regards,
I'll remove this post when re're done.
Called Kerry in my other life
I live at UTC + 13.00
xdcad
Re: From Message
« Reply #1 on: November 27, 2023, 09:27:22 PM »
Thanks,
If I understand correctly,
It is regular. If there are posts that need guidance, I will sort them out and send you a message, and then you can update them.
Not yet, I will contact you if necessary
in addition,
I feel that it might be more convenient for everyone if I could be given management rights in this sub-forum and pin some posts to the top.
Daily management is always troublesome and inconvenient for you. After all, everyone is doing maintenance in their spare time.
Thanks again...
https://github.com/xdcad
http://bbs.xdcad.net
kdub_nz
  • SuperMod
Re: From Message
« Reply #2 on: November 29, 2023, 01:09:04 AM »
XDCad, you have 2 posts prefixed [XDrX-PlugIn(19)] xxxxx
I assume that was an accident ?
xdcad
Re: From Message
« Reply #3 on: November 29, 2023, 01:38:28 AM »
Thank you, I modified it
Dazzled
