Code - Auto/Visual Lisp: [Select](defun C:FENCE-BREAK ( / brk-ss brk-ss-obj-lst crv-en crv-es crv-length crv-obj fence-delta fence-v-lst obj-int-lst ssa x-obj ) (xdrx-begin)..... while in this routine, the selected curve breaks everything it encountershttps://drive.google.com/file/d/1RsY--YTqvqrZ3tdeAUB84gnRBhaBXtpz/view?usp=sharing
Code - Auto/Visual Lisp: [Select](defun :INTERS-OBJ1-OBJ2-MODE (o1 o2 mode / l r) (if(setq l (vlax-invoke o1 'intersectwith o2 mode)) ....... https://drive.google.com/file/d/1OWrF_6Jg6YjT3FbDqhCT-vLvYfuXP3MJ/view?usp=sharingThis is to show the new possibilities introduced by xdrx-curve-getsplitcurvesand it could be helpful if mr. XD will improve the functionality of this routine by using the functions of the XDRX-... package as much as possible
