Author Topic: [XDrX-PlugIn(6)] Intersect two color blocks (HATCH,REGIO,MPOLYGON)  (Read 1020 times)
xdcad
The code written in the forum is mainly to demonstrate the usage of the main functions to be introduced. There may be a better or direct way to implement it.
The following code mainly introduces the AcGe geometry library function and uses the MPOLYGON object to Intersect the HATCH,MPOLYGON,REGION,,Closed Curves(circle,ellipse,*polyline,spline...) entities.(any combination)
  1. ;|Can be between HATCH, REGION, MPOLYGON (any combination)|;
  2. (defun c:XDTB-IntSect (/ e1 e2)
  3.   ;| Use the AcGe geometry library to determine whether it intersects|;
  4.   (defun _hasInterPnts (e1 e2 / g1 g2 intv ret)
  5.     (setq ret
  6.            (and (setq g1 (xdrx-getpropertyvalue e1 "rootloopat" 0))
  7.                 (setq g2 (xdrx-getpropertyvalue e2 "rootloopat" 0))
  8.                 (setq intv (xdge::getpropertyvalue g1 "getinterval" g2))
  9.            )
  10.     )
  11.     (xdrx-object-release g1 g2 intv)
  12.     ret
  13.   )
  14.   (if (and
  15.         (setq e1 (car (xdrx-entsel "\nSelect main color block<Exit>:"'((0 . "HATCH,REGION,MPOLYGON")))))
  16.         (xdrx-pickset-redraw e1 3)
  17.         (setq e2 (car (xdrx-entsel "\nSelect the color blocks to be InterSect<Exit>:" '((0 . "HATCH,REGION,MPOLYGON")))))
  18.         (not (eq e1 e2))
  19.       )
  20.     (progn
  21.       (xdrx-begin)
  22.       (if (_hasInterPnts e1 e2)
  23.         (progn
  24.           (xdrx-get-intersect e1 e2)
  25.
  26.           (xdrx-prompt "\nTwo color blocks were successfully InterSect.")
  27.         )
  28.       )
  29.       (xdrx-end)
  30.     )
  31.   )
  32.   (princ)
  33. )
  34.
« Last Edit: November 26, 2023, 05:39:06 PM by xdcad »
https://github.com/xdcad
http://bbs.xdcad.net
