Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-Function(1)] Entity projected onto the plane of the current UCS
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-Function(1)] Entity projected onto the plane of the current UCS (Read 1061 times)
xdcad
Swamp Rat
WWW
on:
November 24, 2023, 03:41:57 AM »
https://www.theswamp.org/index.php?topic=58129.0
Code - Auto/Visual Lisp:
[Select]
Get the Z axis of UCS
Parameters: none
Return value: vector
defun
XD::UCS:zDir
xdrx_vector_crossProduct
getvar
"ucsxdir"
getvar
"ucsydir"
[Select]
Function name: XD::Project->UCSPLANE
effect:The solid is projected onto the current UCS plane
param:
ss -- Selection or Entity List
return: selection or entity list
defun
XD::Project
UCSPLANE
ss
ents plane g g1 e1
if
type
ss
'PICKSET
setq
ss
xdrx
pickset
ents ss
setq
plane
xdge::constructor
"kPlane"
getvar
"ucsorg"
XD::UCS:zDir
;Coordinate UCS PLANE AcGe kPlane
mapcar
lambda
x
setq
g
xdge::constructor x
; Generate AcGe curve from AcDb curve
setq
g1
xdge::getpropertyvalue g
"orthoproject"
plane
;Geometric curves are orthogonally projected onto the plane plane
setq
e1
xdge::entity:make g1
;Generate entity after projection
xdrx
entity
matchprop x e1
;The entity attributes match the original curve, color, layer, linetype....
xdrx
object
swapid e1 x
;Entity ObjectId exchange to ensure that the newly generated curve entity name remains unchanged
xdrx
entity
delete e1
;Delete the original curve
xdrx
object
release g
;Geometric curve entities release memory
ss
;Select set to entity table
xdge::free plane
;Geometry plane object releases memory
if
type
ss
'PICKSET
xdrx_entity
pickset ss
ss
[Select]
Function name: XD::Project->PLANE
effect:The entity is projected onto the plane specified by the Z-axis vector
param:
normal-- Projecttion Plane Z axis da unit vector
defun
XD::Project
PLANE
ss normal
ents plane g g1 e1
if
type
ss
'PICKSET
setq
ss
xdrx
pickset
ents ss
setq
plane
xdge::constructor
"kPlane"
0
0
0
normal
;Coordinate PLANE AcGe kPlane
mapcar
lambda
x
setq
g
xdge::constructor x
setq
g1
"orthoproject"
plane
setq
e1
xdrx
entity
matchprop x e1
xdrx
object
swapid e1 x
xdrx
entity
delete e1
xdrx
object
release g
ss
xdge::free plane
if
type
ss
'PICKSET
xdrx_entity
pickset ss
ss
[Select]
defun
c:tt
if
setq
ss
xdrx
ssget
\n
Select entities to be projected onto the current UCS plane <exit>:"
progn
setq
ss
xd::project
ucsplane ss
xdrx
entity
redraw
ss
1
princ
Last Edit: December 04, 2023, 01:27:35 PM by xdcad
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
