Author Topic: Please edit the IMF lisp to merge the drawings,Please lisp to merge the drawing  (Read 1835 times)
hcbn1997
I found a pretty good lisp to combine drawing files called IMF. However, Lisp has a disadvantage: the drawings will be connected to each other, the name frames will stick together. Now, I'd like to ask the experts to help me correct the distance for each drawing to be 1000, but it's a bit long to combine 30 drawings.
Or if anyone has a good lisp for merging drawings, please let me know, thank you everyone!
hcbn1997
ĐÂY LÀ LISP IMF FILE LSP
hcbn1997
THIS IS THE REAL SITUATION WHEN LISP HAS NOT BEEN CORRECTED
BIGAL
  • 40 + years of using Autocad
If you look at the code for the insert
(command "-insert"  (strcat pathname "/" filename)    (list xht yht)
You can see the insert point is a list of xht & yht.
So looking further in the code for the add to xht
xht    (+ xht (abs (car (mapcar '- p2 p1))))
Just add an extra 1000
xht    (+ xht 1000. (abs (car (mapcar '- p2 p1))))
Not tested !
hcbn1997
Not tested !
THANKS BRO, I WILL tested
hcbn1997
Not tested !
Lisp is great, thank you again
BIGAL
Just me I would not add in Model but rather make a new layout and insert into that layout. After all that is what layouts are about. Just need a Blank layout to copy.
