Author Topic: XDRX-API specific section?  (Read 5951 times)
Hugo
Re: XDRX-API specific section?
« Reply #45 on: December 04, 2023, 12:39:25 AM »
in ZWCAD almost perfect.
xdcad
« Reply #46 on: December 04, 2023, 02:17:11 AM »
Unfortunately not quite tomorrow
I get an error message
If this error occurs every time, then upload the DWG
https://github.com/xdcad
http://bbs.xdcad.net
Hugo
« Reply #47 on: December 04, 2023, 02:42:49 AM »
The handles on the block are then gone and I can no longer save the dwg
xdcad
« Reply #48 on: December 04, 2023, 03:18:15 AM »
Originally, I did not consider handling the 270-degree situation. Now I have modified the code, mainly the function XD::Text:Adjust
Go and copy this function back and test it
Hugo
« Reply #49 on: December 04, 2023, 03:28:46 AM »
The rotation now works but I get this message 5 times. And then you can no longer save the dwg.
The dwg is then broken.
Danke
Hugo
« Reply #50 on: December 04, 2023, 04:01:23 AM »
I found the error: the block can only have 1 attribute then it works
can this be fixed?
xdcad
« Reply #51 on: December 04, 2023, 04:38:45 AM »
Go and copy the XD::TEXT:ADJUST function again and try
In addition, regarding the problem of this code, it is best to post it under the plug-in post for easy tracking. Thank you.
domenicomaria
« Reply #52 on: December 04, 2023, 07:20:59 AM »
Is there anyone who managed to register on this site
http://bbs.xdcad.net/ ?
If you succeeded, could you kindly explain to me how to do it?
Hugo
« Reply #53 on: December 04, 2023, 07:27:31 AM »
No, I didn't manage that either.
xdcad
« Reply #54 on: December 04, 2023, 07:40:08 AM »
Ordinary registration has been activated, no need to go through QQ. Try it again and let me know the result.
domenicomaria
« Reply #55 on: December 04, 2023, 11:06:18 AM »
@xdcad
result.
the gmail.com domain is not supported
I provided 2 other different email addresses,
and I'm waiting to receive an email to confirm the registration and to choose a password, I suppose, ...
...but the email doesn't arrive...
xdcad
« Reply #56 on: December 04, 2023, 01:16:05 PM »
@xdcad
result.
I sent you a message and I directly registered a user for you.
domenicomaria
« Reply #57 on: December 04, 2023, 09:02:06 PM »
@xdcad
thank you !
Hugo
« Reply #58 on: December 04, 2023, 11:54:57 PM »
It didn't work for me either
