Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
acrx_cmd_transparent, again !
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: acrx_cmd_transparent, again ! (Read 1247 times)
domenicomaria
Swamp Rat
on:
November 12, 2023, 07:13:54 AM »
Code - Auto/Visual Lisp:
[Select]
defun
:POINT2D
STRING
pt
strcat
rtos
nth
0
pt
2
12
rtos
nth
1
pt
2
12
defun
:ADD
TRANSPARENT
CMD
sym
func
name
str
func
name
setq
str
func
name
vl-symbol-name
sym
func
name
vlax-remove-cmd
str
func
name
vlax-add-cmd
str
func
name sym
func
name str
func
name acrx_cmd_transparent
defun
PR
ang dist ptr r
initget
"X"
setq
ptr
getpoint
\n
[eXit] reference point <lastpoint> :"
cond
not
ptr
setq
ptr
getvar
"lastpoint"
ptr
"X"
setq
ptr
nil
and
ptr
setq
ang
getorient
\n
direction <exit> : "
setq
dist
getdist
\n
distance <exit> : "
setq
r
polar
ptr ang dist
vla-SendCommand
vla-get-activedocument
vlax-get-acad-object
strcat
:POINT2D
STRING r
\n
:ADD
TRANSPARENT
CMD 'PR
This code
WORKS WELL
TRANSPARENTLY
in
ACAD COMMAND
and
LISP ROUTINES
but
only if I enter inputs from keyboard and not using the mouse
because
the mouse is locked while this code is running
For istance :
PLINE
... point ... point ...
'PR
(from this moment
the mouse is locked
but
it is possible to enter inputs using the keyboard
... and every thing goes normally ...
I want know why the mouse is locked while the code is running !
Last Edit: November 12, 2023, 07:19:08 AM by domenicomaria
Logged
domenicomaria
Swamp Rat
Re: acrx_cmd_transparent, again !
Reply #1 on:
November 13, 2023, 09:59:05 AM »
a friend of mine tested the code in ACAD 2024,
and it works well!
So it depends from the version of ACAD !
I'm curious if there are any problems in BricsCAD ...
Logged
mhupp
Bull Frog
Reply #2 on:
November 13, 2023, 12:21:08 PM »
i think you also need to tell it where to put the point. not just the active document but model space or paper space.
[Select]
setq
doc
vla-get-ActiveDocument
setq
mspace
vla-get-ModelSpace
doc
vla-SendCommand
doc mspace
strcat
:POINT2D
STRING r
\n
Logged
domenicomaria
Swamp Rat
Reply #3 on:
November 13, 2023, 01:10:51 PM »
@mhupp
ok ... but the main problem is the one I asked in my initial message ... to you, the mouse freezes or not?
When it asks the reference point,
is it possibile to enter a point
using the pointer ?
Last Edit: November 13, 2023, 01:13:54 PM by domenicomaria
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
