Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How to Assign Value in Custom Tab in Dwgprops
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to Assign Value in Custom Tab in Dwgprops (Read 1417 times)
MeasureUp
Bull Frog
on:
November 02, 2023, 05:13:43 AM »
Can anyone please help?
Here is an example.
Supposed there are tens custom property names in the "Custom" tab in "DWGPROPS" dialogue.
If
WeekDay_02
is found in the "Name" column, then
Monday
is to be added to it's value cell.
Thanks in advance.
Logged
Seagull
London, England
WWW
Re: How to Assign Value in Custom Tab in Dwgprops
Reply #1 on:
November 02, 2023, 05:40:25 AM »
The key is the ActiveX
SummaryInfo
object, specifically the
SetCustomByKey
method.
Logged
Lee Mac Programming
Twitter
Exchange App Store
dexus
Bull Frog
Reply #2 on:
November 02, 2023, 06:01:14 AM »
You can use the code
here
and call it with: (getCustomDwgProp "name")
Logged
MeasureUp
Bull Frog
Reply #3 on:
November 03, 2023, 05:18:35 AM »
Thanks Lee. your reply is always informative. I will ask again if having more questions.
And thanks to dexus. Your code is a helpful example and I will learn from it.
Both helps are much appreciated.
Logged
MeasureUp
Bull Frog
Reply #4 on:
November 03, 2023, 06:05:45 AM »
Hi dexus,
How do I apply "if" statement with (getCustomDwgProp "name") function?
I need to search if the name of
WeekDay_02
is found then add
Monday
to the value.
Thanks.
Logged
Seagull
London, England
WWW
Reply #5 on:
November 03, 2023, 09:52:47 AM »
Here's a very basic example -
Code - Auto/Visual Lisp:
[Select]
defun
foo
doc key str
sum
setq
sum
vla
get
summaryinfo doc
if
not
vl-catch-all-error-p
vl
catch
all
apply
'vla
getcustombykey
list
sum key 'out
progn
vla
setcustombykey sum key str
t
[Select]
foo
vla-get-activedocument
vlax-get-acad-object
"WeekDay_02"
"Monday"
Logged
Lee Mac Programming
Twitter
Exchange App Store
MeasureUp
Bull Frog
Reply #6 on:
November 04, 2023, 01:06:46 AM »
Thanks again, Lee.
Last Edit: November 04, 2023, 01:13:31 AM by MeasureUp
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
