Author Topic: Dynamic, Annotative block, parts not scaling as XREF for some  (Read 7570 times)
tedg
« on: September 12, 2023, 02:15:55 PM »
Hey there, it's been a while since I posted here.
We have a dynamic room-tag block, which is annotative, and it works great in the same drawing.
But when xreffed, the top line (which is a multi-line attribute) does not scale at all other than locked at 1/8".
Note, this doesn't happen for everyone, for some users they behave fine as expected even as an xref.
I'm hoping this is some variable or setting that I (and other users) have that we can switch.
I think I've looked at all the variables, and I have "show annotation objects" and "add scales to annotative objects when the annotation scale changes" toggled on
Thanks in advance if anyone has a solution
(an update, a person that had no issues before, does have an issue when looking at certain files, so it may be a bigger problem than for just some)
« Last Edit: September 12, 2023, 03:18:47 PM by tedg »
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
AlexFielder
  • Mosquito
Re: Dynamic, Annotative block, parts not scaling as XREF for some
« Reply #1 on: September 13, 2023, 09:34:46 AM »
Is every system up-to-date patch-wise? (Both Autodesk and Windows!)
tedg
« Reply #2 on: September 13, 2023, 01:55:41 PM »
I'm pretty sure but I will check for sure, thanks
