Author Topic: Dynamic blocks & not overcomplicating things  (Read 1405 times)
AlexFielder
  • Mosquito
« on: September 11, 2023, 09:16:03 AM »
Hi all,
It's been many years since I last needed to create a Dynamic block in AutoCAD (currently using 2024 FWIW).
I have a dynamic block (attached) that I need to do a couple of things:
  • Have multiple variations of the number of "U" shaped brackets - (x, 4, 3 and 2 respectively)
  • Have variations of 1) which have either equi-spaced or manual spacing between the "U" shaped brackets
Am I better off creating individual dynamics blocks for each requirement, or is there some fancy setup I can create using Visibility states/Lookup tables etc.
Thanks,
Alex.
David Hall
  • Automatic Duh Generator
Re: Dynamic blocks & not overcomplicating things
« Reply #1 on: September 11, 2023, 11:43:25 AM »
I used Dyn Blocks for what you are wanting, and it worked great.  But when it came time to change existing parts, it became difficult sorting through the different visibility views and keeping the geometry straight and sorted.  I think I if I planned how to build them better up front, the maintenance of the blocks would not have been so bad.
AlexFielder
  • Mosquito
« Reply #2 on: September 12, 2023, 05:16:48 AM »
Thanks David, as much as I would like/expect Dynamic block visibility states to behave in the same table-driven manner that many functions in Inventor behave (when they behave of course(!)) I think I am going to have to retain the parametric features but forget the visibility states for the reason you state.
