Author Topic: wcmatch returning wrong output  (Read 1839 times)
vincent.r
« on: August 28, 2023, 09:12:50 AM »
Command: (wcmatch "[XX]" "*]*")
T
Command: (wcmatch "[XX]" "*]")
T
Command: (wcmatch "[XX]" "*[*")
nil
Command: (wcmatch "[XX]" "[*")
nil
Why wcmatch function returning nil ?
Re: wcmatch returning wrong output
« Reply #1 on: August 28, 2023, 09:21:55 AM »
Brackets are a special character for the wcmatch function so you need to escape them with a backtick.
Command: (wcmatch "[XX]" "*`[*")
T
dexus
« Reply #2 on: August 28, 2023, 09:22:14 AM »
This works:
  1. (wcmatch "[XX]" "`[*")
As you can see here:
https://www.theswamp.org/Sources/doc/avlisp/#wcmatch
[ is a special character, but can be escaped with a quote: `
vincent.r
« Reply #3 on: August 28, 2023, 09:36:44 AM »
T
Thanks JohnK. Its working.
vincent.r
« Reply #4 on: August 28, 2023, 09:37:33 AM »
This works:
Thanks dexus. Will look into it.
« Reply #5 on: August 29, 2023, 06:47:00 AM »
You could also use vl-string-position or vl-string-search to find a character within a string - these do not accept wildcards and will therefore always treat the supplied arguments as literals.
