Author Topic: Vert Deflections on pressure pipe  (Read 1830 times)
PHX cadie
« on: August 16, 2023, 05:37:55 PM »
Is there a expression of some type to get the deflection angle of 2 pressure pipes, (no fitting, at the moment) on a profile. Currently I cheat, which will always come back.....I draw an alignment across the bottom of pipe on a 1:1 profile, get the deflection from an alignment PI label, explode (yea I know) then copy paste as cheated text into the profile label
Is there a better/non exploded way?
TIA
Acad 2013 and XM
