Author Topic: Set attribute values without opening drawing  (Read 1490 times)
vincent.r
« on: August 12, 2023, 04:19:20 PM »
I am tring to change attribute values without opening drawing. Found Lee's solution here https://stackoverflow.com/questions/49403564/how-to-change-attribute-of-block-using-objectdbx
its not working in my case. Showing error -
The drawing "C:\Users\vincent.r\Desktop\PROJECT FOLDER\23356\20230811\ST0478_E4056-13.dwg" was not found or could not be accessed.
Thanks in advance
Vincy
BIGAL
  • 40 + years of using Autocad
Re: Set attribute values without opening drawing
« Reply #1 on: August 12, 2023, 07:06:30 PM »
Did your filename look like this "C:\\Users\\vincent.r\\Desktop\\PROJECT FOLDER\\23356\\20230811\\ST0478_E4056-13.dwg" ie have dbl backslash.
vincent.r
« Reply #2 on: August 13, 2023, 01:19:58 AM »
Yes it is, bigal.
vincent.r
« Reply #3 on: August 13, 2023, 01:56:02 AM »
I just restarted the AutoCAD & its working now. Thanks Bigal for showing the interest.
RolandOrzabal
  • "memories fade but the scars still linger"
« Reply #4 on: August 16, 2023, 05:31:09 AM »
Try using LeeMac's Batch Attribute Editor...
you only need to open one drawing so you pick the block...
http://www.lee-mac.com/batte.html
