How to change the below code to draw dimension inside rectangle. Sample image attached .Please help
(defun c:test(/ p1 p2 p3)
(and
(setq p1 (getpoint "\n1st point: "))
(setq p2 (getpoint "\n2nd point: " p1))
(setq p3 (getpoint "\n3rd point: " p1))
(setq nv (trans (mapcar '- p2 p1) 1 0 t)
oc (trans '(0.0 0.0 1.0) 1 0 t)
p4 (trans p1 1 nv)
p5 (trans p2 1 nv)
p6 (trans p3 1 nv)
(entmake
(list
'(000 . "LWPOLYLINE")
'(100 . "AcDbEntity")
'(100 . "AcDbPolyline")
'(090 . 4)
'(070 . 1)
(cons 010 (trans p1 1 oc))
(cons 010 (trans p2 1 oc))
(cons
010
(trans
(list (car p6) (cadr p6) (caddr p5))
nv
oc
(cons
010
(trans
(list (car p6) (cadr p6) (caddr p4))
nv
oc
(cons 210 oc)
(setq off 0)
(setq ang1(angle p1 p3))
(setq ang2( angle p1 p2))
(command "_.dimaligned" P1 P2 (polar P2 (/ pi 2) off ))
(command "_.dimaligned" P1 P3 (polar P3 (/ pi 2) off))
