Author Topic: Maybe I'm just thick - Cond question...  (Read 2800 times)
CHulse
« on: July 27, 2023, 10:20:55 AM »
OK, maybe I'm just thick. Is one of these 2 snippets correct? Are they the same?  :uglystupid2:
  1.                                 (cond
  2.                                         ((not(or(equal "UPD Not Found" TXT1) (equal "" TXT1)))
  3.                                                 (setq TXT TXT1)
  4.                                         )
  5.
  6.                                         ((not(or(equal "UPD Not Found" TXT2) (equal "" TXT2)))
  7.                                                 (setq TXT TXT2)
  8.                                         )
  9.
  10.                                         ((not(equal "" FULL))
  11.                                                 (setq TXT FULL)
  12.                                         )
  13.
  14.                                         ( T
  15.                                                 (setq TXT "NO TAG#")
  16.                                         )
  17.                                 );;_end cond
  18.
  1.                         (setq TXT
  2.                                 (cond
  3.                                         ((not(or(equal "UPD Not Found" TXT1) (equal "" TXT1)))
  4.                                                 (TXT1)
  5.                                         )
  6.
  7.                                         ((not(or(equal "UPD Not Found" TXT2) (equal "" TXT2)))
  8.                                                 (TXT2)
  9.                                         )
  10.
  11.                                         ((not(equal "" FULL))
  12.                                                 (FULL)
  13.                                         )
  14.
  15.                                         ( T
  16.                                                 ("NO TAG#")
  17.                                         )
  18.                                 );;_end cond
  19.                         );;_end setq
  20.
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Re: Maybe I'm just thick - Cond question...
« Reply #1 on: July 27, 2023, 10:35:46 AM »
#2 is better. #1 reads like a second-grader's writing practice.
In essence, #2 reads like this: "Define the `TXT` variable and fill it with the results of the following conditional." #2 is a very common construct.
d2010
« Reply #2 on: July 27, 2023, 10:58:54 AM »
If you have C++ experinced, then
--you replace
--with
   (equal TXT2 "UPD Not Found").
CHulse
« Reply #3 on: July 27, 2023, 12:40:52 PM »
Thanks guys
I've got a gremlin I can't ferret out and I thought it was this. I thought #2 was correct, but keep getting a nil return. I shall look elsewhere...
Why does the order of the elements matter after the "equal"?
Much appreciated.
Cary Hulse
« Reply #4 on: July 27, 2023, 01:02:07 PM »
The order of the elements matters in the higher order languages because of the "=" and "==" functions. One "tests" and the other "sets" equality.
It looks like your variable `TXT` will/should have at worse case contain "NO TAG#". Tracking down Booleans is difficult (first reason why #1 above is "incorrect" and #2 is "correct"). ...people love to toss around '(or (this) (that) (dosomething (somethingelse (setq...))))' around their code with very little thought about the returns of those statements.
CHulse
« Reply #5 on: July 27, 2023, 01:54:05 PM »
Helpful, thank you. I'm struggling to get better at this and be able to do more than just stealing and tweaking other's programs.
I am still stumped by this though. The logic here seems sound to me, and I think the construct is correct, but it isn't assigning a value to TXT (always nil).
The watch shows me this:
TXT = nil
TAG2 = "598"
TAG1 = "UPD Not Found"
FULL = "t598"
So the second cond should return T correct?
Either way, TXT should get "NO TAG#" if nothing else, and it isn't.
I'm clearly missing something...
  1.                         (setq TXT
  2.                                 (cond
  4.                                                 TXT1
  5.                                         )
  6.
  8.                                                 TXT2
  9.                                         )
  10.
  11.                                         ((not (null FULL))
  12.                                                 FULL
  13.                                         )
  14.
  15.                                         ( T
  16.                                                 "NO TAG#"
  17.                                         )
  18.                                 );;_end cond
  19.                         );;_end setq
  20.
Cary Hulse
« Reply #6 on: July 27, 2023, 02:35:34 PM »
What--exactly--your statement is doing at a specific point in operation is a bit vague (we don't have enough information really to comment on which statement will be true) but this COND construct will not return TRUE/NIL it will return the value of the expression.
For example see if you can determine what var2 will be set to.
  1. (setq var1 1)
  2. (setq var2
  3.       (cond
  4.         ((eq var1 7) var1)
  5.         ((eq var1 6) "twenty one")
  6.         ((eq var1 1) 42)))
It looks to me as your variable `txt` should be set to `no tag#` (the last condition). What is the `txt` variable supposed to do?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #7 on: July 27, 2023, 04:47:35 PM »
--you replace
--with
It's not often I see the point of d2010 posts but in this case I agree.
'is the value of X "yes" '
Called Kerry in my other life
I live at UTC + 13.00
« Reply #8 on: July 27, 2023, 05:09:55 PM »
Is it TAG1 & TAG2 or TXT1 & TXT2 ?  What your Watch says vs the code.
CHulse
« Reply #9 on: July 27, 2023, 05:47:02 PM »
OMG. I have the variables named wrong.  :uglystupid2:
Any wonder it doesn’t work.
Thanks.
Cary Hulse
« Reply #10 on: July 28, 2023, 01:18:30 PM »
FWIW this:
  1. (or (equal "UPD Not Found" txt1) (equal "" txt1))
Could be this:
  1. (wcmatch txt1 "UPD Not Found,")
CHulse
« Reply #11 on: July 28, 2023, 03:10:54 PM »
FWIW this:
Could be this:
Interesting
Thanks Ron
Cary Hulse
« Reply #12 on: July 31, 2023, 03:31:20 PM »
FWIW this:
Could be this:
Interesting
Thanks Ron
Anytime :)
BIGAL
  • 40 + years of using Autocad
« Reply #13 on: July 31, 2023, 06:59:20 PM »
For me a simpler way to read the cond
             ((wcmatch txt1 "UPD Not Found")(setq txt TXT1))
             ((wcmatch txt2 "UPD Not Found")(setq txt TXT2))
             ((null FULL)(setq txt full))
             ((setq txt "NO TAG#"))
     );;_end cond
« Last Edit: August 01, 2023, 08:47:54 PM by BIGAL »
bruno_vdh
« Reply #14 on: August 01, 2023, 03:32:35 AM »
Hello,
FWIW this:
  1. (not(or(equal "UPD Not Found" TXT1) (equal "" TXT1)))
Could be this:
  1. (/= "UPD Not Found" txt1 "")
