Author Topic: Microsoft Guard Class  (Read 2727 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: July 11, 2023, 07:37:42 PM »
Has anyone played with this ??
https://learn.microsoft.com/en-us/dotnet/communitytoolkit/diagnostics/guard
The CommunityToolkit.Diagnostics package contains APIs to efficiently validate method parameters and to throw exceptions in faulting code paths. It is meant to be used to help simplify all argument checks and to make them more expressive and easier to read, while at the same time improving codegen quality and performance.
This package can be installed through NuGet, and it has the following multi-targets:
.NET Standard 2.0
.NET Standard 2.1
.NET 6
This means the package can be used on any available runtime (including .NET Framework, .NET Core, UWP, Unity, Xamarin, Uno, Blazor, etc.).
The Guard can be used to validate method arguments in a streamlined manner, which is also faster, less verbose, more expressive and less error prone than manually writing checks and throwing exceptions.
Code - C#: [Select]
  1. public static void SampleMethod(int[] array, int index, Span<int> span, string text)
  2. {
  3.     Guard.IsNotNull(array);
  4.     Guard.HasSizeGreaterThanOrEqualTo(array, 10);
  5.     Guard.IsInRangeFor(index, array);
  6.     Guard.HasSizeLessThanOrEqualTo(array, span);
  7.     Guard.IsNotNullOrEmpty(text);
  8. }
  9.
Prior to C#10 the syntax is :
Code - C#: [Select]
  1. Guard.IsNotNull(array, nameof(array)))).
  2. //instead of :
  4.
It's basically a ready built specific assert API with a supporting 'ThrowHelper' class
I haven't had a play yet.
Looks interesting, to my mind.
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: Microsoft Guard Class
« Reply #1 on: July 11, 2023, 10:51:50 PM »
Fluent Assertions also looks attractive.
Recommended by Scott McFarlane ( Being a Remarkable C# .NET AutoCAD Developer SD12077 )
https://fluentassertions.com/introduction
https://fluentassertions.com/basicassertions/
https://github.com/fluentassertions/fluentassertions
https://www.nuget.org/packages/FluentAssertions/6.11.0?_src=template
or through NuGet Packages in Visual Studio
kdub_nz
  • SuperMod
« Reply #2 on: July 11, 2023, 11:04:56 PM »
Nice and clean
Added packages.config :
Code - XML: [Select]
  1. <packages>
  2.   <package id="FluentAssertions" version="6.11.0" targetFramework="net48" />
  3.   <package id="System.Runtime.CompilerServices.Unsafe" version="4.5.0" targetFramework="net48" />
  4.   <package id="System.Threading.Tasks.Extensions" version="4.5.0" targetFramework="net48" />
  5. </packages>
  6.
« Last Edit: July 11, 2023, 11:26:14 PM by kdub_nz »
kdub_nz
  • SuperMod
« Reply #3 on: July 11, 2023, 11:55:32 PM »
and a test of Guard Class from MS
  1. <packages>
  2.   <package id="CommunityToolkit.Diagnostics" version="8.2.1" targetFramework="net48" />
  3.   <package id="System.Buffers" version="4.5.1" targetFramework="net48" />
  4.   <package id="System.Memory" version="4.5.5" targetFramework="net48" />
  5.   <package id="System.Numerics.Vectors" version="4.5.0" targetFramework="net48" />
  6.   <package id="System.Runtime.CompilerServices.Unsafe" version="6.0.0" targetFramework="net48" />
  7.   <package id="System.Threading.Tasks.Extensions" version="4.5.4" targetFramework="net48" />
  8. </packages>
  9.
kdub_nz
  • SuperMod
« Reply #4 on: July 12, 2023, 01:24:26 AM »
Some days are Diamonds :)
beer o'clock
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: July 12, 2023, 08:27:39 AM »
I’m still on the fence about exceptions vs something like std::expected
Wonder if .net has something similar
57gmc
« Reply #6 on: July 12, 2023, 11:14:29 AM »
Interesting...looks like I should.
Jeff H
« Reply #7 on: July 12, 2023, 03:17:59 PM »
Cool stuff
