Author Topic: FYI: The next AutoCAD version will target .NET 8 instead of .NET Framework 4.8  (Read 4013 times)
huiz
  • Certified Prof C3D
It is interesting news for us programmers. Though not publicly, but it has now been confirmed by Autodesk that AutoCAD 2025 will target .NET 8. Fortunately the AutoCAD API has not changed, but the challenge for us are the changes in .NET itself.
So, be prepared :-)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
If that's for real, it's good news.
I don't see it as a problem for programmers on this side of the wrapper.
We just have a half dozen years of language improvements to catch up on.
I'm interested in the source of the info though :)
Called Kerry in my other life
I live at UTC + 13.00
It's Alive!
  • Retired
  • AKA Daniel
Woohoo, exciting!
I read there’s an upgrade tool in visual studio to help convert projects.
kdub_nz
  • SuperMod
a couple I've just seen.
https://learn.microsoft.com/en-us/dotnet/core/porting/
https://learn.microsoft.com/en-us/dotnet/architecture/modernize-desktop/example-migration
I've put off looking seriously at the recent versions ( too frustrating ) . . . looks like it's time then  ;-)
huiz
It's Alive!
  • Retired
  • AKA Daniel
I'm in ADN & Beta.... but  :whistling:
Atook
  • AKA Tim
Will existing .NET code need to be updated? It sounds like we just get new/updated .NET tools around the same wrapper.
Hopefully BricsCAD follows suit.
It's Alive!
  • Retired
  • AKA Daniel
I think so, I think some of the .net namespaces have changed.
I'm sure BricsCAD will.. probably V25 though, I'm guessing it's a lot of work as module loading has changed
kdub_nz
  • SuperMod
Would be 'nice' if they can support .net 8
The slated officially release is in November 2023, and it's a LTS (Long Term Support) version for 3 years.
That would be better than starting with release 7 and have to update to 8 later, with possible breaking changes.
Though really, 7 would be better than staying where we are I think . . . at least the language features will be familiar for both library and desktop development.
niggling thought:  the Chatgpt and mrs Google code searches may require a bit more refinement to weed out garbage and outdated code.
Atook
  • AKA Tim
Does this open up the possibility that we can develop/deploy .NET code to/from Mac and Linux? Too much to hope for?
It'd be pretty cool competition wise if I could step to a Linux/BricsCAD approach.
I hope we get edit->continue debugging back.
« Last Edit: July 21, 2023, 12:11:03 PM by Atook »
It's Alive!
  • Retired
  • AKA Daniel
Interesting question, the current wrappers are use C++/CLI. Last I researched, MS was not going to port this to other platforms
https://devblogs.microsoft.com/cppblog/the-future-of-cpp-cli-and-dotnet-core-3/
So, it’s C++ or Lisp for those platforms.  Or some adventurous person could make Python wrappers, since Python and wxWigets are already cross platform.
Not me though, I tried to compile a couple of BRX apps for Linux, and it was painful, just because I don’t know the OS well
« Last Edit: July 25, 2023, 01:39:41 AM by Pai Mei »
kdub_nz
  • SuperMod
CADbloke
  • Crash Test Dummy
This will make supporting older versions of AutoCAD interesting, even more interesting than the 2013 release.
57gmc
I need to get a book and catch up on core.  :whistling:
kdub_nz
  • SuperMod
Just an update for anyone who missed it :
Next Release of AutoCAD API, AutoCAD 2024 + 1 will be planning to support NET Core technology.
We have released an alpha on our feedback portal.
AutoCAD alpha is targeted to support NET 6.0
AutoCAD betas and the final release is targeted to support NET 8.0.
https://adndevblog.typepad.com/autocad/2023/08/call-for-action-next-release-of-autocad.html
