Author Topic: Fill in the gap of my nested item  (Read 430 times)
topshelfvalueinc
  • Mosquito
« on: May 21, 2023, 12:45:49 AM »
So i have a program that i am using to nest shapes into a contained area ( sheet of foam ) and sometimes my nested items do not fill the full sheet. for example my foam size is 72x120 inches, if i cut a 24x72, 24x96, and then im left with a space of 48x96. im trying to make a code that will give me the best optimized items from the list below to fill in the space for little to no waste. My sizes that i can use to fill in the dead space is 24x72, 24x84, 24x96, 24x120, 30x72, 30x84, 30x96. What im hoping is a function that i can give a list of items that will be nested and it will output 2 pieces 24x96 or it would say if instead of it being 48x96 inches left over i had 54x96 it would say 1 piece 30x96 1 piece 24x96
ribarm
  • Marko Ribar, architect
Re: Fill in the gap of my nested item
« Reply #1 on: May 21, 2023, 03:15:49 PM »
Maybe this topic will give you some ideas to try to code for your needs...
https://www.theswamp.org/index.php?topic=52260.0
M.R. on Youtube
topshelfvalueinc
  • Mosquito
« Reply #2 on: May 21, 2023, 03:38:56 PM »
Yes so i found one that nests and it works amazingly but im looking for something that will add parts into the nest on sizes i use usually if the sheet isnt fully used, for example i have the drawing below, its already been nested now i need to know from the sizes below, which sizes are best used to maximize the remaining spaces, 24x72, 24x84, 24x96, 24x120, 30x72, 30x84, 30x96
« Last Edit: May 21, 2023, 03:49:06 PM by topshelfvalueinc »
topshelfvalueinc
  • Mosquito
« Reply #3 on: May 27, 2023, 04:43:45 PM »
willing to pay for this if someone can figure it out for me
mhupp
« Reply #4 on: May 29, 2023, 03:19:41 PM »
Free website to calculate this. I think you can use spread sheets to speed up the inputs.
Only really calculates rectangles areas I think.
https://www.cutlistoptimizer.com/
« Last Edit: May 29, 2023, 03:27:19 PM by mhupp »
topshelfvalueinc
  • Mosquito
« Reply #5 on: June 08, 2023, 09:26:15 PM »
how do i get the formula that it uses?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #6 on: Today at 03:35:37 AM »
I'd assume it's under lock and key on their back end server.
Called Kerry in my other life
I live at UTC + 13.00
some people complain about loading the dishwasher
Sometimes the question is more important than the answer.[/i
