Bricsys has a really good support system, you can always file a request and ask if they have plans to improve GrDraw, its always been a bit clunky
IMHO, if youre using ObjectDBX heavily, it might be time to move to another API such as .NET.
Instead of using GrDraw, you would use a draw jig, with much smoother operations.
No I am not using the ObjectDBX that much, back in the day (those AutoCAD days when it had lifetime licensing) I hade some routines using it and they stopped working after moving from AutoCAD to ZWCAD. At this point I have no use for ObjectDBX so I guess I'll leave that as is. And in case needed, maybe there is another way to get data out of a drawing without actually opening it.
You mention grdraw has always been a bit clunky, so maybe this is a part for me to just accept it or not. I mean, it does work, just not that smooth... Moving to another API is a no go for me, I feel that is too complicated for me.
"Bricsys has a really good support system" what do you mean by that? After testing I will for sure want to buy a lifetime licence, does Bricsys offer any support after purchase? I mean most of the time support is only 'given' through annual subscriptions?
There are a couple of commands that work differently say compared to Autocad I found polygon to be one so just do a simple check look at version if it has "Bricscad" then do in a slightly different way, I have V20 so no "Reverse" command but (command "Pedit" ent "R") works in both.
True: in both ZWCAD as in BricsCAD the reverse command is not available as it is in AutoCAD. But this is to be solved with a minor routine. The Polyline Edit (PE) function however is present in all three softwares.
I have added a screenshot of the programs ribbons stacked on top of each other, there is so much similarity. If you would have to choose only on that part, either choice would be good. I feel AutoCAD still has the most intuitive ribbon, BricsCAD the least. But there is so much more that is important, the looks are not that important. Main reason for not using AutoCAD is the price per year through annual subscription. If it were not for the price we would 100% stick to that. ZWCAD does come as a lifetime licence and therefore it is the cheapest of them 3. Compared to BricsCAD it feels more fluent, the screens are more bright, the ribbon is mor intuitive and it comes closest to AutoCAD in most cases e.g. the options dialog. Then why choosing BricsCAD? Because in the Netherlands there is no professional reseller of ZWCAD. Their sites are not up to date and the seem very unprofessional. And also, no offense meant to anyone, Bricsys does have it headquarters in Belgium an not in China. Last but not least: compared to AutoCAD there is so limited information availible about ZWCAD, if feel I might be better of with BricsCAD when it comes to support/help/forum.
Maybe this topic should be closed as the discussion is not specifically about lisp anymore. in that case I want to thank you all for joining in this topic.
