Author Topic: Displaying the attributes from some identical blocks?  (Read 3241 times)
Peter2
« on: March 22, 2023, 08:42:47 AM »
The properties palette can show the content of attributes from blocks.
But only one, and only permanent until the selection of the next element.
"data Extraction" shows the content of many blocks.
But needs definition and many clicks and is not modeless (permanently opened).
Is there a tool inside Autocad / bricscad which
- displays the attribute-values of (identical) blocks (e.g. in a "sheet")
- only with one or two clicks
- modeless (displayed permanently and independent from next commands.)
Thanks for advice!
Peter
BricsCAD V23
