Author Topic: New Project Step 1 Linetypes  (Read 17485 times)
David Hall
  • Automatic Duh Generator
« Reply #30 on: July 11, 2005, 09:52:05 AM »
Im back, and things are better than we had first heard.  I'll leave it at that so we dont completely HiJack this thread
David Hall
« Reply #31 on: July 11, 2005, 11:05:17 AM »
So did anyone think about code over the weekend?  Was anyone able to come up with some error checking based on error number using Select Case?
daron
« Reply #32 on: July 11, 2005, 11:14:21 AM »
Not me, sir. I helped with an eagle scout service project that wiped me out. I never slept so much as I have this past weekend.
David Hall
« Reply #33 on: July 11, 2005, 11:19:08 AM »
Had to come back to work to get some rest?  Been there and done that.
daron
« Reply #34 on: July 11, 2005, 11:31:53 AM »
No, the project lasted from 8am to noon. When I got home I went to sleep. Sunday after church, I went to sleep again and no, I didn't fall asleep at church. Trying to keep kids quiet and still will keep you plenty active and awake. Anyway, let's get this back on track:
Get to those error traps. Good idea to introduce them early, Dave.
David Hall
« Reply #35 on: July 11, 2005, 11:38:26 AM »
Based on This Post does anyone have an idea of how we can trap for errors in loading linetypes?
David Hall
« Reply #36 on: July 12, 2005, 10:40:56 AM »
OK, so anyone have any ideas?
David Hall
« Reply #37 on: July 12, 2005, 11:13:39 AM »
Given the example I posted earlier,
Dim A as interger
A=3
Select Case A
Case 1:
Msgbox "A = 1"
Case 2:
Msgbox "A = 2"
Case 3:
Msgbox "A = 3"
Case Else:
Msgbox "A is not in the List"
End Select
Lets look at what is going on in this code.  First I have to create the variable, A, so Dim A as integer.
Im using an integer just as an example.  Then Set A=3.  So everyone agrees A=3 right?  OK, now the
Select Case statement.
Select Case A - which means, evaluate A, and see if it matches any of the choices that follow.
Case 1:   - which means Does A=1?  No, so go to next case.
Case 2:    Does A=2?  No, go to next case
Case 3:     Does A=3?  Yes, so do what follows which is a messagebox that says A=3
Had A not equaled 1, 2, or 3, the Case Else: would have been used as a catch all,  w/ a box that said A is not in list.
Now how could we use that logic and trap an error for loading a linetype?
Public Sub LLINE()
On Error GoTo ErrorHandler
End Sub
We start by telling the code to GoTo the ErrorHandler if there is a problem.  Following this, we can begin coding our app.
At some point, we put in the error handler
Public Sub LLINE()
ThisDrawing.Linetypes.Load "HIDDEN", "ACAD.LIN"
ThisDrawing.Linetypes.Load "DASHED", "ACAD.LIN"
Exit Sub
ErrorHandler:
End Sub
OK, so we have told Vb to use the error handler if needed, and we go to our first line, which says load the Hidden linetype.
If the linetype is already loaded, VB will raise an error code, specifially code " -2145386405" which is what we want to trap on.
 So,
Public Sub LLINE()
ThisDrawing.Linetypes.Load "HIDDEN", "J:\TEP SUPPORT\ACAD.LIN"
ThisDrawing.Linetypes.Load "DASHED", "J:\TEP SUPPORT\ACAD.LIN"
Exit Sub
ErrorHandler:
Select Case Err
Case -2145386405:
Err.Clear
Resume Next
Case Else:
Err.Raise Err.Number, Err.Source, Err.Description, Err.HelpFile, Err.HelpContext
End Select
End Sub
So if Err = -2145386405, Clear the Err and then resume the program with the next line.
Knowing that the error was caused by the linetype already being loaded, we can trap that and move on without the user seeing
an error message.
Was everybody able to generate an error message before?  Was the number the same?  It should have been, because that is the number for duplicate linetypes
« Reply #38 on: July 12, 2005, 12:09:59 PM »
Yes to both.
On the code you posted. I still get the error dialog when I run the program. Or are we supposed to.
David Hall
« Reply #39 on: July 12, 2005, 12:12:27 PM »
no, your not supposed to, what code did you type in?  the -2145386405 number was the one we were searching for.  Can you post your code?
« Reply #40 on: July 12, 2005, 12:22:11 PM »
I used your code two posts up.
In the dialog I get
run-time error '-2145386405 (8020005b)':
duplicate record name
David Hall
« Reply #41 on: July 12, 2005, 12:44:15 PM »
I could have typoed as well  hold on
David Hall
« Reply #42 on: July 12, 2005, 12:47:34 PM »
in the IDE, go to Tools->Options, General Tab, Error Trapping,  Are you set on Break on all errors?  Set to Break on UnHandled Errors
« Reply #43 on: July 12, 2005, 12:59:22 PM »
Quote from: CmdrDuh
That worked. :oops:
David Hall
« Reply #44 on: July 12, 2005, 01:00:19 PM »
Dont feel bad.  That one had me stumped for days when I got started
