Author Topic: New Project Step 1 Linetypes  (Read 16332 times)
David Hall
  • Automatic Duh Generator
« Reply #15 on: July 08, 2005, 12:23:50 PM »
Quote from: daron
Heh. I did that for Linetypes property, but I do see where I was going wrong. No parens.
and no = sign needed either
daron
« Reply #16 on: July 08, 2005, 12:30:52 PM »
That too. I'd like to ask what's next, but I'd like to see the others who want to learn this stuff not fall behind. Are there any questions on how we got to the ThisDrawing module? Beuller?
David Hall
« Reply #17 on: July 08, 2005, 12:38:21 PM »
Whats next you ask.....  Well, what happens if you run your code twice?
daron
« Reply #18 on: July 08, 2005, 01:04:37 PM »
It errors because there is no On error resume next or something like that. actually, since I already had those loaded, they errored out in the first place.
daron
« Reply #19 on: July 08, 2005, 01:10:39 PM »
BTW, Dave, congrats on being able to control this place.
David Hall
« Reply #20 on: July 08, 2005, 01:19:59 PM »
Quote from: daron
Thanks, I was a mod at another site for a few years, so I asked Mark if I could mod this forum only.  When you posted your example with the code tag backwards, I was like..... eerrrrrggh, that is so frusterating not to be able to fix that.  Fortunetly you saw and fixed it.
David Hall
« Reply #21 on: July 08, 2005, 01:27:10 PM »
Quote from: daron
RIGHT!  Now a word about On Error Resume Next
Gurus can chime in if you disagree, but this is the worst kind of error checking in my opinion.  It does work, and it is better than nothing, but its the lazy way out.  Someday, you will have a situation where you need to catch the error and deal with it, and if you use this all the time, it will pass through and you will have no chance to fix the problem.
Now why did the example use it you ask?  Well, the people at Autodesk can in no way anticipate what you are going to do, and they know your going to copy and paste, so they put that in so when you run it for the first time, and your just learning VBA, it works.  Your linetypes load, your happy, and you move on.
So what is a better way of catching the error?  Use Select Case.
example to follow.
David Hall
« Reply #22 on: July 08, 2005, 02:18:26 PM »
For the LISPers out there, Select Case works like the COND statement in lisp.  From the Help File
Executes one of several groups of statements, depending on the value of an expression.
Syntax
Select Case testexpression
[Case expressionlist-n
[statements-n]] ...
[Case Else
[elsestatements]]
End Select
where the testexpression is what you are testing against.  the Case Expression is the match value, and the statements is what to do
so here is an example
Dim A as interger
A=3
Select Case A
Case 1:
Msgbox "A = 1"
Case 2:
Msgbox "A = 2"
Case 3:
Msgbox "A = 3"
Case Else:
Msgbox "A is not in the List"
End Select
Now there is more that would go into our error checking, but does everyone get the idea?
daron
« Reply #23 on: July 08, 2005, 02:49:24 PM »
I think so.
Birdy
« Reply #24 on: July 08, 2005, 03:26:11 PM »
<Not wanting to get left behind>
Yeah, been kinda following this thread, but gotta do a lotta work today too. :(
Will play a little catch-up this evening.
David Hall
« Reply #25 on: July 08, 2005, 03:42:23 PM »
Quote from: Birdy
Im not going to cover much more today, as I want everyone who is following along to get a chance to work on this.  IF you are so inclined (or bored) this weekend, add an error checking function in our LoadLineType function.
Use the error number, and return a message box to the user saying its already loaded.  If any other number comes up, give the user a message box that has the error number and description.
There are good examples in the online help, and in the docs we have already posted in the Course forum.  Im avail for PM and email this weekend as well.
Birdy
« Reply #26 on: July 08, 2005, 03:48:36 PM »
:) thanks.
David Hall
« Reply #27 on: July 08, 2005, 10:00:04 PM »
i have had a family emergency come up and will probably be unavailable this weekend.  I will try and check in, but there is no guarentee.  See you guys on Monday
« Reply #28 on: July 08, 2005, 10:06:47 PM »
Sorry to hear that David, see ya Monday.
David Hall
« Reply #29 on: July 08, 2005, 10:53:41 PM »
Ill give an update as I can
