Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
File size is upnormal
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: File size is upnormal (Read 3860 times)
HasanCAD
Swamp Rat
on:
February 13, 2023, 06:39:38 AM »
Hi All,
This file size is upnormal even when is empty.
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
Peter2
Swamp Rat
Re: File size is upnormal
Reply #1 on:
February 14, 2023, 05:36:20 AM »
Seem to be some dictionaries, and maybe one is damaged ..
https://www.afralisp.net/autolisp/tutorials/dictionaries-and-xrecords.php
Logged
Peter
BricsCAD V23
HasanCAD
Swamp Rat
Reply #2 on:
February 15, 2023, 02:17:50 AM »
How to detect damaged dictionaries?
Logged
Donate to Theswamp
www.sergiwa.com
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Reply #3 on:
February 15, 2023, 02:52:32 AM »
this one and the one below it have 600-700 entries.
they are customs objects so my utility won't purge them
maybe one of these will
https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=200809200499705
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
Needs a day job
Reply #4 on:
February 20, 2023, 11:32:27 AM »
You can use this to analyze drawings too:
http://www.theswamp.org/lilly_pond/mp/lisp/counts.txt
Logged
dexus
Bull Frog
Reply #5 on:
February 21, 2023, 03:07:34 AM »
I quickly combined
DCL List Tile Dependency (Lee Mac)
with a loop through the dictionaries.
This way you can look through what dictionaries are in the drawing.
No other functionality yet. Repair/delete/find empty etc. would be great.
Code - Auto/Visual Lisp:
[Select]
defun
c:dictBrowser
*error*
dch dcl des lst rtn
; Based on http://www.lee-mac.com/listtiledependency.html
defun
*error*
msg
if
'file
type
des
close
des
if
0
dch
unload_dialog
dch
if
and
'str
type
dcl
findfile
dcl
vl-file-delete
dcl
if
and
msg
not
wcmatch
strcase
msg t
"*break,*cancel*,*exit*"
princ
strcat
\n
Error: "
msg
princ
if
and
setq
lst
getDict
entget
namedobjdict
setq
dcl
vl-filename-mktemp
"tmp.dcl"
setq
des
open
dcl
"w"
foreach
str
"lbx : list_box"
" alignment = centered;"
" fixed_width = true;"
" fixed_height = true;"
" width = 30;"
" height = 30;"
"test : dialog"
" label =
Dictionaries in current drawing:
" spacer;"
" : row"
" : lbx { key =
lb0
; label =
Dictionary
" : lbx { key =
lb1
; label =
Items
" spacer;"
" ok_cancel;"
write-line
str des
not
setq
des
close
des
0
setq
dch
load_dialog
dcl
new_dialog
"test"
dch
progn
setq
rtn '
0
0
LM:dcld:action '
"lb0"
"lb1"
'lst 'rtn
if
1
start_dialog
princ
strcat
\n
The user selected:"
substr
apply
strcat
mapcar
lambda
x
strcat
x
LM:dcld:getitems rtn lst
2
princ
\n
*Cancel*"
*error*
nil
princ
defun
getDict
lst
itm rtn ed
while
setq
itm
assoc
3
lst
setq
ed
cdr
assoc
350
lst
setq
ed
cons
strcat
cdr
assoc
5
entget
ed
mapcar
remove
nil
function
lambda
e
if
car
e
3
cdr
e
entget
ed
setq
rtn
cons
cons
cdr
itm
list
ed
rtn
lst
cdr
member
itm lst
reverse
rtn
defun
ALE_Fix_Dictionaries
EntDct
OutLst
vlax-for
VlaFor EntDct
if
vlax-property-available-p
VlaFor 'Name
setq
OutLst
cons
cons
vlax-get
VlaFor 'Name
VlaFor
OutLst
reverse
OutLst
defun
ALE_Fix_DelDictionaries
DctNms
foreach
ForElm
vla-get-dictionaries
vla-get-activedocument
vlax-get-acad-object
if
wcmatch
car
ForElm
DctNms
progn
try '
vla-delete
list
cdr
ForElm
p
"Dict Deleted"
car
ForElm
princ
defun
mapcar
remove
nil
func lst
item rtn
;; mapcar-remove-nil - dexus ;;
;; A combination of (vl-remove nil (mapcar ... )) in one function. ;;
;; This function will apply the provided function to all elements ;;
;; of a list, if the return of the function is true than the item ;;
;; will be added, otherwise it will be removed. ;;
;; func: [list] Function to apply to all elements in list, if ;;
;; result is nil the item will be removed ;;
;; lst: [list] List of items to process ;;
;; returns: [list] List of all returns from func that were not nil ;;
while
lst
if
setq
item
apply
func
list
car
lst
setq
rtn
cons
item rtn
setq
lst
cdr
lst
reverse
rtn
;; DCL List-Tile Dependency - V2.1 (2019-04-27) - Lee Mac
;; Configures action_tile statements for the list of keys to enabled dependency between the DCL tiles.
;; key - [lst] List of DCL tile keys in order of dependency
;; lst-sym - [sym] Quoted variable containing list data
;; rtn-sym - [sym] Quoted variable containing initial selection indexes
defun
LM:dcld:action
key lst
sym rtn
sym
defun
LM:dcld:addlist
key lst
start_list
key
foreach
itm lst
add_list
itm
end_list
defun
LM:dcld:getlists
idx lst
if
cdr
idx
cons
mapcar
car
lst
LM:dcld:getlists
cdr
idx
cdr
nth
car
idx
lst
lst
defun
LM:substnth
itm idx lst
if
lst
if
zerop
idx
cons
itm
mapcar
lambda
x
0
cdr
lst
cons
car
lst
LM:substnth itm
1-
idx
cdr
lst
defun
LM:dcld:actions
key lst
sym rtn
sym lvl
fun
setq
fun
if
cdr
key
list
lambda
val lst
list
setq
rtn
sym
list
'LM:substnth '
atoi
val
lvl rtn
sym
list
'LM:dcld:addlist
cadr
key
list
nth
1+
lvl
list
'LM:dcld:getlists rtn
sym 'lst
list
LM:dcld:actions
cdr
key
lst
sym rtn
sym
1+
lvl
list
set_tile
cadr
key
"0"
'lst
list
lambda
val lst
list
setq
rtn
sym
list
'LM:substnth '
atoi
val
lvl rtn
sym
action_tile
car
key
vl-prin1-to-string
list
fun '$value lst
sym
fun
mapcar
'LM:dcld:addlist key
LM:dcld:getlists
eval
rtn
sym
eval
lst
sym
eval
LM:dcld:actions key lst
sym rtn
sym
0
set_tile
car
key
itoa
car
eval
rtn
sym
eval
lst
sym
princ
;; DCL List-Tile Dependency - Get Items - Lee Mac
;; Returns a list of the items selected from each dependent list tile.
;; idx - [lst] List of selection indexes
;; lst - [lst] List data
defun
LM:dcld:getitems
idx lst
tmp
if
cdr
idx
cons
car
setq
tmp
nth
car
idx
lst
LM:dcld:getitems
cdr
idx
cdr
tmp
list
nth
car
idx
car
lst
Logged
Needs a day job
Reply #6 on:
February 21, 2023, 10:49:24 AM »
Quote from: HasanCAD on February 13, 2023, 06:39:38 AM
Hi All,
The old wblock trick knocks this file down to 96 kb.
[Select]
command
"_.-wblock"
strcat
getvar
'dwgprefix
getvar
'dwgname
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
