Author Topic: A function in the Properties bar  (Read 3288 times)
tsdlc888
  • Mosquito
« on: January 05, 2023, 09:49:40 PM »
Greetings of new year to you.
What autocad function is the section in the properties bar which i marked blue in the attached drawing so i can search for tutorials of doing one. The data appears in that properties ONLY when i click a polygon in the drawing and there is no text in the drawing  I think it does not function in lower version of autocad. Btw i use Autocad 2019 Landdesktop. Thank you
57gmc
Re: A function in the Properties bar
« Reply #1 on: January 06, 2023, 10:37:40 AM »
That is map data attached to the polyline. What is your goal? Are you trying to write a program to work with map data? If so, what programming language do you use? Map 3D has a lot of tools built in.
I don't see that Autodesk supports LDT anymore. I use Map 3D and others here use Civil 3D, which is built upon Map 3D. For better help, let us know what you are trying to do.
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: February 01, 2023, 09:30:50 PM »
Google Object data OD Lisp there are function examples out there, get / put etc.
