In general, whenever attempting to ascertain where particular data is stored within the DXF data for an entity, I would always suggest creating an entity (be it graphical or non-graphical, such as a layer) with the target properties, and then inspect the DXF data using a utility such as my
Entity List function (or a similar function of the same nature).
For your case, you might observe data such as the following:
(-1 . <Entity name: 7ff434803900>)
(0 . "LAYER")
(5 . "10")
(102 . "{ACAD_XDICTIONARY")
(360 . <Entity name: 7ff4348051e0>)
(102 . "}")
(330 . <Entity name: 7ff434803820>)
(100 . "AcDbSymbolTableRecord")
(100 . "AcDbLayerTableRecord")
(2 . "0")
(70 . 0)
(62 . 7)
(6 . "Continuous")
(290 . 1)
(370 . -3)
(390 . <Entity name: 7ff4348038f0>)
(347 . <Entity name: 7ff434803e00>)
(348 . <Entity name: 0>)
(-3
"AcAecLayerStandard"
(1000 . "")
(1000 . "Layer 0 Description")
Note also that you may need to use
regapp to register the
AcAecLayerStandard xdata application ID if such ID is not already registered in the drawing.
