i discovered your issue with int64, inside Borland-Delphi BDS..
They, BdsTeam found, reserarch team,
the first step at integer64, is==
"blocked the variable Types inside entire.program" ![sleezy :sleezy:](http://www.theswamp.org/Smileys/black/sleezy.gif)
How to block the AllVariablesLisp with one type?
How to block the AllVariablesLisp.vlx with one type?
(setq a1int 100 or nil)
(setq a2real 3.14 or nil)
