This problem should be analyzed from the Underlying technology, and the two writing methods should be compiled into Fas respectively. The decoded FAS is like this
Offset 0 1 2 3 4 5 6 7 8 9 A B C D E F
00000000 0D 0A 20 46 41 53 34 2D 46 49 4C 45 20 3B 20 44 FAS4-FILE ; D
00000010 6F 20 6E 6F 74 20 63 68 61 6E 67 65 20 69 74 21 o not change it!
00000020 0D 0A 31 31 36 0D 0A 31 31 20 24 14 03 02 02 00 116 11 $
00000030 09 0A 00 5C 00 00 09 09 00 5C 01 00 18 05 00 09 \ \
00000040 08 00 51 01 07 00 01 00 0A 03 09 00 35 01 06 00 Q 5
00000050 03 06 09 00 03 0A 00 5D 02 00 5C 02 00 32 00 4B ] \ 2 K
00000060 67 1C 00 00 00 5C 02 00 50 5D 02 00 35 00 09 00 g \ P] 5
00000070 03 03 05 00 35 02 04 00 03 06 05 00 57 D9 FF FF 5 W?
00000080 FF 03 05 00 35 01 03 00 03 19 03 00 16 14 00 00 5
00000090 00 00 03 02 00 35 01 01 00 03 0B 06 02 00 16 24 5 $
000000A0 0D 0A 32 30 39 20 36 20 24 14 01 01 01 00 32 00 209 6 $ 2
000000B0 32 2F 2A 39 01 00 5B 58 00 52 45 50 45 41 54 54 2/*9 [X REPEATT
000000C0 4F 4C 49 53 54 00 00 01 01 43 00 00 04 00 0A 32 OLIST C 2
000000D0 62 32 74 2A 32 00 32 62 2A 39 02 00 5B 31 2B 00 b2t*2 2b*9 [1+
000000E0 58 00 52 45 56 45 52 53 45 00 43 4F 4E 53 00 52 X REVERSE CONS R
000000F0 00 45 56 41 4C 00 00 56 5F 61 6C 2D 62 69 6E 64 EVAL V_al-bind
00000100 2D 61 6C 69 73 74 00 00 5B 52 00 00 39 01 00 5B -alist [R 9 [
00000110 46 00 49 00 00 5C 00 00 43 00 00 0B 00 0A 5C 00 F I \ C \
00000120 00 32 62 5B 2D 6C 61 6D 62 64 61 2D 00 00 3A 5C 2b[-lambda- :\
00000130 00 00 32 00 5B 52 45 50 45 41 54 54 4F 4C 49 53 2 [REPEATTOLIS
00000140 54 00 00 3A 01 43 04 00 02 00 1C 14 01 00 00 00 T : C
00000150 09 03 00 0A 57 00 00 00 00 09 05 00 06 02 00 09 W
00000160 02 00 0A 32 00 0B 06 01 00 0A 32 05 57 00 00 00 2 2 W
00000170 00 09 04 00 35 02 02 00 03 16 17 00 87 FD 12 D2 5 圐 ?
00000180 9A 4D 9C 0A 3B 66 61 73 34 20 63 72 75 6E 63 68 歁?;fas4 crunch
00000190 0A 3B 24 3B 41 34 2F 32 2F 32 32 ;$;A4/2/22
This is the first way to write
00000020 0D 0A 39 38 0D 0A 39 20 24 14 03 02 02 00 09 08 98 9 $
00000030 00 5C 00 00 09 07 00 5C 01 00 18 05 00 09 06 00 \ \
00000040 51 01 05 00 01 00 0A 03 07 00 35 01 04 00 03 06 Q 5
00000050 07 00 03 08 00 5D 02 00 5C 02 00 32 00 4B 67 1C ] \ 2 Kg
00000060 00 00 00 5C 02 00 50 5D 02 00 35 00 07 00 03 03 \ P] 5
00000070 03 00 35 02 02 00 03 06 03 00 57 D9 FF FF FF 03 5 W?
00000080 03 00 35 01 01 00 03 19 03 00 16 24 0D 0A 32 31 5 $ 21
00000090 36 20 36 20 24 14 01 01 01 00 32 00 32 2A 2A 39 6 6 $ 2 2**9
000000A0 01 00 5B 4C 41 4D 42 44 41 00 00 01 5B 53 45 54 [LAMBDA [SET
000000B0 51 00 00 5B 58 00 00 5B 31 2B 00 00 5B 58 00 00 Q [X [1+ [X
000000C0 39 02 00 39 03 00 39 03 00 5B 58 00 52 45 50 45 9 9 9 [X REPE
000000D0 41 54 54 4F 4C 49 53 54 00 00 01 01 43 00 00 05 ATTOLIST C
000000E0 00 0A 32 00 32 62 2A 39 01 00 5B 52 45 56 45 52 2 2b*9 [REVER
000000F0 53 45 00 43 4F 4E 53 00 52 00 45 56 41 4C 00 00 SE CONS R EVAL
00000100 56 5F 61 6C 2D 62 69 6E 64 2D 61 6C 69 73 74 00 V_al-bind-alist
00000110 00 5B 52 00 00 39 01 00 5B 46 00 49 00 00 5C 00 [R 9 [F I \
00000120 00 43 00 00 09 00 0A 5C 00 00 32 00 5B 52 45 50 C \ 2 [REP
00000130 45 41 54 54 4F 4C 49 53 54 00 00 3A 01 43 05 00 EATTOLIST : C
00000140 01 00 1C 14 01 00 00 00 09 04 00 0A 57 00 00 00 W
00000150 00 09 05 00 06 03 00 09 03 00 0A 32 00 0B 06 02 2
00000160 00 0A 32 05 09 01 00 35 02 03 00 03 16 15 00 F9 2 5 ?
00000170 CC B8 D7 42 0A 3B 66 61 73 34 20 63 72 75 6E 63 谈譈 ;fas4 crunc
00000180 68 0A 3B 24 3B 41 34 2F 32 2F 32 32 h ;$;A4/2/22
This is the second way to write
It can be seen that the first method defines two functions, red and green, and the second method has only one function.
In other words, the first method is to compile lambda into ordinary functions. In the second method, lambda is not a function.(LAMBDA NIL (SETQ X (1+ X ) ) ) is a list,It is interpreted and executed, so the speed is slow.
Acad's help file says that the function of lambda is to define a function without name. It is equivalent to the function defined and called now, because it is nameless and cannot be called elsewhere.
After analyzing the fas file, it is found that it is no different from general functions, except that all Lambdas use the same function name -lambda-
