Author Topic: Ortho Not Working with GRREAD, but Polar Tracking is  (Read 773 times)
cmwade77
« on: February 24, 2022, 07:55:42 PM »
I am rewritting my leader routine for a variety of reasons and I am having trouble getting Ortho to function, but I have polar tracking working.
I have attached the drawing that contains all of the necessary leader styles and blocks as well as my routine so far.
I am sure that I am missing something obvious, if someone can take a look and let me know, I would greatly appreciate it.
I wouldn't be surprised if there are more efficient ways to do a lot of this as well.
EDIT: Updated version on ULEADER - 02/25/2022
« Last Edit: February 25, 2022, 02:00:57 PM by cmwade77 »
ribarm
  • Marko Ribar, architect
Re: Ortho Not Working with GRREAD, but Polar Tracking is
« Reply #1 on: February 25, 2022, 02:08:36 AM »
Not sure, but, try this :
Insert at line 645 this part :
(645) ...
         (if (getvar "ORTHO")
           (setq IncrementAngles nil)
That should be all...
For somewhat different approach to ORTHO functionality look here :
http://www.theswamp.org/index.php?topic=12813.msg526700#msg526700
Regards, M.R.
M.R. on Youtube
cmwade77
« Reply #2 on: February 25, 2022, 01:59:40 PM »
It was even slightly more complicate than that, line 588 had to be changed to (if (or (bitcodef (getvar "autosnap") 8) (= (getvar "ORTHOMODE") 1)) it was (if (or (bitcodef (getvar "autosnap") 8) (getvar "ORTHO"))
I also had to adjust line 668 accordingly and line 671 was expanded to:
(if (not (= (getvar "ORTHOMODE") 1)
            (grdraw pt1 (polar Pt1 (angle Pt1 FinalPoint) 10000) 3 1)
I also had to move your suggestion and modify it a bit.
I was also able to remove some additional information from my original code. I have attached what I presently have.
